Thread: Would these cause cutout? as though ignition been turned off
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Default Would these cause cutout? as though ignition been turned off
    P0335 Crankshaft Position Sensor A Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P1481 Fan Secondary Low With High Fan On
    I have just done the brake/accelerator fault code test and these are the codes it brought back
    I recently had a thread on this forum about my cut outs located here: http://www.vectra-c.com/forum/showthread.php?t=100667
    As stated in the old thread i thought (hoped more like) that it was the battery at fault but ive just had the engine cut out on me once again today on a very busy dangerous road and i am not willing to move the car again till it is sorted or until i pour a gallon of petrol over it and set it alight
    It cut out as though i had turned the key... no juddering etc just a clean cut off. It then wouldnt start (i tried it about 6-7times) so i turned all head unit/blowers off etc, got out of the car to see if i could see a problem under bonnet, got back in and tried once again and it started no problem... Is this some thermal/heat issue?
    Can any of the codes i have given cause this problem? (the transmission one sounds major :/ )
    I have the car booked in for proper diagnostics on monday but im getting really worried as i can't afford a £1k bill... would like to be prepared for worst case scenario
    thanks
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0335 MAY cause engine to not fire (some engine do and some don't), and failing during running would result in clean cut off if so.
    Check the sensor wiring, plug and cleanliness...
    P0700 - maybe depends, can't really comment as I'm not an auto transmission expert
    P1481 - Engine Coolant Blower Motor Relay 1 Malfunction, DEFO not cause engine cutoff.
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Cheers.
    0700 sounds expensive its the main thing im worrying about
    Regular Member affirmation's Avatar
    May 2008
    Pembs
    I had exactly the same problem - but teh codes given out were ECU needs reprogramming/replacing. Anyone long and short of it - replacing the ECU after every other test was the result - i also had a service (£140 ish) and the total bill came to £850 that included over hunderd for electrical tests and teh service charges.- if it looks like its going to be replacement ECU dont have the tests first just get it done and it should be around the £500 mark - harsh pill to swallow - i hope its not the same fault for you mate. but mine would just cut out with no warning and then start again after a little bit. I alos had teh emissions warnign light come on whnever the fault was present (although there was nothing wrong with the emissions system)
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Yes that sounds the same problem i am having but i really hope it isnt
    I really cant justifiy to myself spending over £500 to repair a £3k car + i cant really afford it at the moment being a landscape gardener work isn't exactly busy with recent weather conditions :/
    Unfortunately i think it will be a case of selling up and getting a different car if it is the case really hoping its not, but we'll see monday
  1. Exhaust cutout for 2.8t
    By donkmeister in forum Petrol Engine related
    Last Post: 24th January 2013, 10:48
  2. Turned ignition key, no power...
    By izonoky in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2012, 13:05
  3. Urgent help. 1.8 cutout
    By Edmunds-Sri in forum Engine & Drivetrain
    Last Post: 14th May 2010, 22:35
  4. Vectra 3.2 05 Gsi clicking noise when ignition turned on/off
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 19:36
  5. Series of beeps whrn the ignition is turned on
    By DeathStar in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2009, 19:54
