Thread: Vectra Flip Key
    Jul 2009
    NEWPORT
    Default Vectra Flip Key
    Well i just thought i would share this information with you all being daft i got a key from ebay it came cut to size just had to be linked with the car payed over the odds for it but thats another story i also got another one from ebay 2nd hand and it cost me alot less. My mate tried to link this new one up to the car and we could not get it to work went to Vaux on Tuesday and gave them the 2 keys and asked them to programme them for me when i pick the car up only one key would programme and guess what ? it was the 2nd hand one so YOU CAN re-programme 2nd hand keys as with the new one im trying to get my money back below is the information on the keys
    The one that wont work
    Delphi 13 214 966 433MHz G3-AM433TX V10 4406
    The one that does work
    Delphi 93 187 511 433MHz G3-AM433TX V10 1306
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    how do you find out the key number thing IE: delphi 13 214 xxx xxx also I bought a insignia key used. do you think I could get this coded as vauxhall said they can only code the new insignia keys once.
    Jul 2009
    NEWPORT
    [quote=kdadidog;1159848]how do you find out the key number thing IE: delphi 13 214 xxx xxx[/quot
    Its on the inside where the flip key sits just flip the key and you will see the numbers on the fob just looked at a web page and this type of key would fit
    Vauxhall Vectra C 2002-2008
    Vauxhall Signum 2003-2007
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...DLVI%26ps%3D54
    This key is cheaper at Vauxhall had a quote of £46 +VAT for the key only
    [quote=3.2wales;1159851]
    Quote Originally Posted by kdadidog View Post
    hmmm any other way as I have scraped it a bit in there so key wouldnt stick as I had it specially made for this fob
    there is a number like this. GM13500232
    Jul 2009
    NEWPORT
    It maybe the insignia part number if its after 2008
    Jul 2009
    NEWPORT
    Im 100% sure you wont get this to work with the vec as the transponder is not the same when it goes into opcom it will say key code not recognized
    yes...it says programming failed in op-com.
    Sodding Typical on Sea
    I have the two keys my car came with so I plan on getting new shell's possibly new blades cut and re-using the circuit board as from opening them, the switches are in great shape just the casing is rough.
    I did one already and it all went perfectly works locks unlocks flips and looks brand new!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    my key is 13 214 966 and it works fine! was coded up with Vaux-com.
    It said first failen.. then did it again there it worked.
  1. 3 button non flip key internals fit straight into a flip key shell???
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 01:44
  2. Vectra c 3 button flip key help please someone
    By matrix1979 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 22:29
  3. Vectra C Flip Keys Watch what you buy
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2009, 07:19
  4. Vectra Flip Key
    By korlinski in forum General Chat
    Last Post: 5th September 2007, 12:03
  5. New Flip key for vectra
    By suj786 in forum General Chat
    Last Post: 18th December 2005, 11:52
