Results 1 to 10 of 11
Thread: Programming the auto gear box?
    Regular Member TopRod's Avatar
    Liverpool, UK
    Default Programming the auto gear box?
    Would just like to know can the auto gear box on the 08 Vectra be programmed to change gears at different speeds? At the moment it doesn't change From 3rd to 4th untill I get to 40mph and from 4th to 5th untill 53ish mph. I'd like to change it to about 35mph for 4th and 49 or 50mph for 5th. Would vauxhall do it or would I have to find a specialist? Thanks, ste.
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Good question. I'd like to do the same with my 2.2 Elite Auto.
    The 'downhill' logic could do with some extra programming too. Sometimes it notices you are going down a steepish incline, and decides to invoke engine braking by changing down a gear (whatever your speed...). Normally not a bad idea, but with so many hills here in Bradford, it soon becomes annoying as the downchange is done with very little finesse...
    Our gearboxes are supposed to be 'adaptive' - the ratios are supposed to change with your driving style. I drive really slowly - but the gearchanges have not adapted.
    Anyway, look forward to some opinions...
    Jun 2007
    Black Country
    I thought the auto boxes were self learning, so if you drive slow the gears change slow, if you drive fast, they change faster to suit
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    try using it manual?
    Winteringham
    to reset auto box to self learning mode disconnect battery for 30min then go for drive and box will learn your style of driving.
    Bradford
    Trim : Elite Auto
    The manual mode is ok for changing up (eg 3rd to 4th) but it still uses pre-determined ratios for changing down (and it will change down, even if you dont). ie it will put you back in 3rd at 30mph. Hence when trying to drive round town at 30ish mph you tend to hover between 3rd and 4th as the gearbox hunts and 'does its thing'.
    Jun 2007
    Black Country
    Quote Originally Posted by gregc View Post
    Why do that?
    If i take it easy for 5 mins while driving around, the engine revs lower and the gears chnage up sooner for better fuel efficient driving
    If I go round the streets eating boy racers, the gears change at much higher revs and the fuel consumption goes down
    If I had to disconnect the battery everytime me and the other half changed seats, Ive never have the bonnet down
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    I think one of us has a problem.
    Mine is in 5th gear at 30mph,something i really like because of the extra economy it gives.
    I do however agree with the downhill thing,really pi$$es me off at times.
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Quote Originally Posted by ShamusUK View Post
    The ratios never change, its the 'Shifting' times that change depending on how you drive it....AKA....Adaptive. Im not entirley sure how many adaptive modes there are on the boxes....I assume the 6spd autos will adapt slightly differently to the 5spd autos.
    I do know that when the wife drives it (miss daisy) the gear changes are Not that smooth and change up early, when i drive it (Normal driving) the gear changes adapt well and change when i would but when i drive it 'properly'....the gear changes are much later and definatley give it a more sporty feeling BUT the fuel stops are much earlier...
    Oh and mines got the 5spd.
    Dont think a dealer will be able to reprogramme the box, This will be a specialised job which will mean new software being written for the gearbox..££££££.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    You can re-programme the box as there's a VX TIS2000 field remedy for shift flare from 2nd to 3rd:
    Subject:AF 23/33 -5 Transmission - Delayed 2 - 3 upshifting / shift flareModels:Engines:Option:Vectra-C 2002...2003,Signum 2002...2003Z22SE| Y22DTR| Z32SE| Y30DT| Z22YH,Z22SE| Z22YH| Z32SE| Y22DTR| Y30DTComplaintelayed upshift ( approx. 3 - 5 sec.) during upshift from 2 to 3. The engine speed increases by 200-400 RPM.Cause:Transmission-oelpressure varying during upshift from 2 to 3.Production:As of MY 04 modified software and hardware (Transmission and TCM) have been introduced.
    Remedy:
    In case of customer complaint reprogram TCM with Software as of TIS 2000 CD 52.
    HTH
  1. help with tech2 programming auto AFL
    By emsedk in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2012, 16:54
  2. vxr auto gear box remap
    By leedslads in forum Petrol Engine related
    Last Post: 29th February 2012, 23:55
  3. auto gear box help anyone?
    By lukesignum in forum Engine & Drivetrain
    Last Post: 25th September 2010, 00:30
  4. Auto gear changes
    By Alansilverfox in forum Engine & Drivetrain
    Last Post: 13th June 2009, 19:56
  5. Auto gear box only 2nd & 5th pls help!!!
    By watkins1172 in forum Engine & Drivetrain
    Last Post: 12th January 2009, 19:48
