Results 1 to 10 of 14
Thread: Now i'm worried
    Regular Member braveheart's Avatar
    Jul 2009
    Scotland
    Default Now i'm worried
    I have a 1.9 150 which had all the usual symptoms of an EGR valve problem so followed to how 2 to clean it, drill out the solenoid etc and figured i'd clean the boost sensor at the same time.
    After i had put everything back in place i tried to fire it up to no avail. I kept trying and eventually itsounded as if it was going to start as normal then it would just die. I kept turning it over and after about 15 tries it stayed on.
    The problem though is that is was coughing and spluttering away at about 600 revs and sounded like it was about to give up any second and the amount of smoke coming out the exhaust would have been enough to melt the ice caps.
    Whenever i press the accelerator absolutely nothing happens so my car is totally undriveable in this state, at least i could drive it before if i hammered it up to 2500 revs.
    I really need my car up and running so if anyone can give me some help i'd really appreciate it. Cheers.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Was your EGR completely dry when you put it back on, and is everything connected and tight?
    Wales, UK
    Disconnect the battery for 30 mins or so ? If theres a fault, would this perhaps clear it ?
    Jul 2009
    Scotland
    I used carb cleaner on the EGR to clean it then used some 40+ on the solenoid parts for lubrication. It was all dry on the ooutside when i connected it back up. The solenoid didn't move as freely as i think it should have even after everything though. When i connected both parts of the EGR back together the solenoid was springing against the other part meaning i had to hold them together tightly while putting the 4 torx screws back in, should this have been the case? Would this keep the valve open all the time?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by braveheart View Post
    Check you have tightned all the nuts/bolts as I made that daft mistake and thought I ruined the car.
    Gazza4
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Could be a knackered EGR. Same happened to me at the weekend with the same symptoms. Fitted a new EGR yesterday and it flies now.
    Jul 2009
    Scotland
    Will do Gazza, i'm sure i double checked them all though.
    Samdy, cheers for that, maybe i should check my local Vx dealership tomorrow and just see if i can get a new one then. How much did it cost you?
    Is it something they'd be likely to have in stock?
    Wales, UK
    Ive heard they are like £150 os something silly. Double check but if this is the case, it might be worth a look on ebay..
    http://cgi.ebay.co.uk/Vauxhall-Astra...item35a58ae673
    Jul 2009
    Scotland
    Cheers for the link mate.
    Jul 2009
    Wiltshire, UK
    I paid £50 for mine on eBay, but I have the 1.9 [120] which is slightly cheaper.
  1. seriously worried
    By mikecoz in forum Engine & Drivetrain
    Last Post: 29th January 2013, 23:17
  2. Someone please help im worried!
    By dannyjpuk in forum General Chat
    Last Post: 15th February 2011, 17:03
  3. Bit worried, might be over nothing!
    By george1987 in forum Engine & Drivetrain
    Last Post: 7th April 2010, 21:29
  4. Should i be worried?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 22:41
  5. Bit worried
    By SRIRob in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 20:03
vectra c nothing happens when I press accelerator
