Results 1 to 10 of 11
Thread: Rear brake pad wear
    Oct 2009
    N.Ireland
    Default Rear brake pad wear
    Discovered a wierd problem with my rear brakes today, changed the rear pads, the passanger side ones were knackerd, no pad life left at all but the drivers still had a decent bit of pad left, anyone know why this is? And do i have a serious problem that i should get sorted?
    Regular Member wotsthestory's Avatar
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Caliper knackered? I just had to have my rear caliper replaced, on the passenger side also, as it jammed on and we were unable to wind it back.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds as though one side is stuck on or the other side is stuck off bud
    Oct 2009
    N.Ireland
    Does that mean the piston inside the caliper is knackerd?
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    However the pads on the rear were absolutely bare, nothing there. Had just got the car and hadn't noticed (scary). I suspect them being so low didn't help in my case!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Basically, yeah. Calipers aren't too expensive though. Didn't you have any problems winding the piston back in?
    Oct 2009
    N.Ireland
    No not at all which is wierd went back in no probs and i cant feel anything unusual when im braking?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I'd just keep an eye on them then mate, especially if the breaking feels fine. May even be worth taking it to an mot test station and paying to get the back brakes tested on the rollers
    Oct 2009
    N.Ireland
    Yea was thinking that to mate, it passed the m.o.t at the end of november there. A mate of a mate lol works in the local test centre so il see if i can get him to get ot on the brake test thing and see if there any imbalance etc
    Jun 2007
    Carshalton
    Engine : 3.0 CDTI
    Mileage : 103000
    Just take it for an MOT test, they'll check it over as they would for the test, if it passes without issue, you've got an extra 2 months.
  1. Brake wear sensor put where?
    By kenp in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 23:33
  2. Brake Pad Wear Sensors
    By MadTogger in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 10:25
  3. Rear brake pad wear - a warning !!
    By blueboy in forum Handling & Braking
    Last Post: 5th October 2009, 19:59
  4. uneven brake wear ?
    By Lump in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2009, 20:24
  5. Uneven rear brake wear
    By Wingnut in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 20:51
