Results 1 to 10 of 11
Thread: Any Sky Installers lurking about?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Any Sky Installers lurking about?
    Ordered Sky HD and am getting it installed tomorrow but am only getting one input from my current Sky+ box. This only started a day or so ago and have tried fiddling with the cable, tried putting the cable into another outlet on the LNB, reset the Sky+ box but cannot get the second signal.
    I am hoping the installer will be able to source the problem tomorrow, unless Sky do something to block the signal before HD is installed?
    Basically, question is, when upgrading from Sky+ to HD, would I get a new LNB or is the installation just swapping the boxes about?
    Oct 2009
    lincoln
    Just swap the box mate, i would ring sky, and tell the installer tomorrow.
    WGAF#5
    as andy said - they only fit a new black box - nothing on the lnb unless you got for multiroom and need a quad or and octo block fitting
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    when i had my sky hd fitted the engineer has to check the dish,if it is not working he has to replace what is needed as the dish and lnb is also part of the guarantee
    Regular Member braveheart's Avatar
    Jul 2009
    Scotland
    Dunno if you got this installed yet or not but the installer is coming out to do a full standard install for you, which includes a new dish, LNB and all cabling if required. You are tying yourself in for 12 months here so there is no option for them, they need to install it properly otherwise the job will be cancelled.
    Tain - Easter Ross
    So I should have got a new dish and LNB?
    Jul 2009
    Scotland
    Only if it was required, there's no point in replacing them if they work fine.
    Jan 2010
    Liverpool
    They should fit a new LNB and wiring if its duff.
    They noticed mine was dodgy when I upgraded to HD from + and replaced the lot.
    Tain - Easter Ross
    Our dish could not get a signal anywhere on the house so it was put on a tree in the garden with the wires running down near a hedge. My neighbour has managed to cut the wire 3 times so has quite a few joins. I did mention this to the installer on Thursday but all he did was replace the joints with F-type connectors, did OK but not as good as a new cable would have been.
    Replaced that cable on Friday with some coax my old man had but it is slightly thinner and has a braided core as opposed to a solid core on the original stuff. On the settings, one signal is good and one is minimal.
    Would the tree growing cause any problems and is cable with a solid core better?
    Kingston Upon Hull
    My Mum & Dad had a new sky box etc fitted this week and they fitted every thing new dish the lot
    Jacko
  1. Any Roofers/Guttering Installers on Here?
    By Rebellion in forum General Chat
    Last Post: 26th June 2012, 19:51
  2. clifford installers
    By rochey in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2010, 23:32
  3. Bluetooth Installers
    By sshaikh in forum Insignia car chat
    Last Post: 30th September 2010, 14:03
  4. Satellite installers
    By Daywalker in forum General Chat
    Last Post: 17th November 2009, 17:36
  5. Audio installers in Bucks area
    By johnny kebab in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 14:58
