Thread: Signum FogLight Bulb Replacement
    May 2006
    Mansfield
    Default Signum FogLight Bulb Replacement
    Hi All,
    Owners manual says that "I should entrust bulb replacement to my dealer". -
    Not at £50+ a time as a friend of mine did. Has anyone done this ?. I presume its a minimum of wheel arch liner off, or is it more complex ?
    SJ
    Melbourne, Australia
    A reliable source says the procedure goes something like this:
    To remove bulb
    1. Unscrew cover (1)
    2. Release retaining spring (2)
    3. Remove bulb
    4. Disconnect wiring harness plug (3)
    Then do the reverse to put the new one in.
    Regular Member SirGSi's Avatar
    England
    If it's anything like the GSi (MY2003) then it should be easy(ish).
    I managed to squeeze under the front bumper (head and shoulders) without having to even jack the car up.
    As per the piccies, just unscrew the cap and disconnect the wire from the chasis.
    HTH
    Grant.
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    HI,
    I have changed the fog lamps in my signum like in the pics, but you dont have to remove the wheel liner! only an access cover under the bumper, you need to unscrew one torx bolt and the flap pulls down to uncover the back of the fog lamp!
    I had to jack up the car to allow safe access!
    hope this helps
    Woodsta!
    May 2006
    Mansfield
    Default Thanks Everyone
    Will try this at the weekend and will do a "how to", time and wife permitting......
    SJ
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Other option... and really a lot less knuckle grinding.
    1. Remove the front bumper - Explained HERE - takes 15 mins max.
    2. Full access to the foglights - no covers, no reaching through floor trays, under the car, through wheel liners etc.
    Reason I prefer this method is that I can never keep my fingers off the bulb whilst fiddling through the wheel arches.
  1. '56 Signum Elite 3.0CDTI bulb replacement
    By Reid in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2011, 13:50
  2. foglight bulb replacement
    By aerodynamic18 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2009, 18:37
  3. Replacing foglight bulb
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2008, 13:21
  4. Bulb replacement on 06 Signum
    By dazza1964 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2007, 12:38
  5. SRi Foglight bulb?
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2006, 02:02
signum fog light bulb
