Thread: Replacing DMF
    Jan 2010
    Bradford
    Default Replacing DMF
    Hi folks,
    I've recently aqcuired an 70k 04 plate Vectra Sri 1.9 150 CDTI Estate.
    The clutch needs changing as its slipping.
    Do you recomend the DMF gets changed as well?
    I've got the Job priced up to include the DMF, but if its something that doesn't actually need changing I won't bother.
    Oh, and does anyone know wether its likely to have a DPF?
    Cheers,
    Rik
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    From what I've read it's usually the other way round the DMF goes and you replace the clutch at the same time. It might be worth searching the forum for people describing the sounds of a failing DMF and if you can hear it even slightly then it would definitly be worth changing at the same time.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    yes, you do have a DPF. Shouldn't be any problem unless it short journeys everywhere.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Quote Originally Posted by RikD View Post
    Hi folks,
    Cheers,
    Rik
    had mine done just before xmas mate........clutch specialist in leeds......£580 he charged me..........
  1. Replacing cim ?
    By Mr Owens in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 10:10
  2. replacing the REC
    By les287 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2011, 04:14
  3. egr needs replacing?
    By family guy in forum Engine & Drivetrain
    Last Post: 20th April 2011, 10:41
  4. Replacing Tie Rod and Tie rod end
    By chazuwe in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2011, 13:46
  5. Replacing the CIM
    By Martyn21 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:22
