Thread: 12V Live
    Jan 2010
    Glasgow
    Default 12V Live
    Hi,
    Hope someone can help. Replacing my CD30 unit with an aftermarket bluetooth ipod set up. Have got all harnesses, fascias, adaptors etc but apparently I need to wire the red wire on the new unit to a 12v live feed. Is there an easy way to do this? I'm not too competent when it comes to electrics nor do I have anyone close by to assist. Any advice would be most helpful.
    Thanks Phil
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    You could take it to the 12v cig lighter feed underneath the cig lighter/power socket just under the radio, just cut into the wire and split off. Easy to remove the trim/power socket and the wires are under it might be better access under the ashtray.
    Full Member lizard's Avatar
    Oct 2006
    southampton
    15 Post(s)
    If you have bought the iso adaptor for your car then there will be a permanent live and and ignition live coming from the new iso adaptor. Permanent live could be either yellow or red depending on where you bought the iso adaptor from... HTH
    hull
    my cig lighter didn't have a permanent live feed, so ran a wire straight from the battery through a grommet behind the glovebox.
    used inline fuse just incase.
    Jan 2010
    Glasgow
    Thanks guys,
    Got the harness on ebay with no instructions. I'll try the cigarette lighter. Thanks for your assistance.
    Phil
    Jan 2010
    Glasgow
    Thanks Lizard,
    Connected it to the red on the original loom and its working fine. Many thanks.
    Phil
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Is the cig lighter Switch Live or Perm Live
    By jake.clay in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2011, 12:48
  3. Wot fuses for a live qwn u turn key and a switched live
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:15
  4. Were to take a switched live and a live from for a boost gauge
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 15:02
  5. Xbox live?? C.o.d 4??? Other live games.
    By baz_rochdale in forum Games Room
    Last Post: 21st October 2009, 20:28
