Results 1 to 2 of 2
Thread: Heater/ventilation - speed selector problem.
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Default Heater/ventilation - speed selector problem.
    hy all
    Can someone had this problem on Climate Control module?
    The problem is when I turn the wheel to select the speed for heater fan....it`s jumps over the numbers...I mean from 0 if i have to put on number 3....i turn 3 times to the right....but when i turn it`s going to speed no 5 then 4 then 3.....
    And the confirmation button...also don`t work very fine...if I want to push the button, I need to push more harder then normally .... and sometimes it`s going ok, sometimes not.
    I attach some pictures to see what part need`s to be changed....and if you know how is the name of this part (or a code number because i found just a little one like 09481T and I found nothing by this code), please tell me...because I want to change this part...
    Thanks.
    When mine did that I just bought a complete unit for £80 from car parts connexions. Should be £230+ from the dealers. Although the old one was a bit scratched too.
  1. Heater Fan not working on speed 1, Speeds 2,3,4 ok
    By lehapau in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 20:02
  2. Gear selector or clutch 6 speed Turbo
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 1st September 2011, 20:57
  3. prob with heater fan speed dial
    By bobk1 in forum Bodywork & Interior
    Last Post: 22nd March 2011, 02:31
  4. heater blower only works on 4 speed
    By hippo in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 9th February 2010, 14:38
  5. Ventilation/Climate Control Problem
    By a18nmk in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2007, 08:18
09481t
