Thread: Facelift rear bumper removal Urgent.
    Sep 2009
    Glasgow
    Default Facelift rear bumper removal Urgent.
    Hi all attempted to remove rear bumper today to fit reversing sensor kit, all going well just had to give some little tugs to release bumper it wont budge, followed the how 2 guide 2 the letter, any suggestions, off on holiday all week so have time to attempt it again.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    be brave it will come mine took some persuading
    Sep 2009
    Glasgow
    there seems to be clips at both light clusters do these need uncliped
    Nov 2007
    The are at the sides of the light clusters ... yes they do the again just pull to unclip...
    Sep 2009
    Glasgow
    will try again tommorrow, seems really tight also can only see 2 screws in wheel arches.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Been a while since I removed mine on a 56-plate vec-150 I used to have, but is there not 2 screws that are located (underneath) above the number plate ?
    certainly recall 2 screws being there as well, though it may have been on front bumper, worth a check anyway.
    Blantyre
    Loosen the torx inside the wheel arches, make sure the rear light are removed, then slide your hand in from the wheel arch and push out, worked a treat everytime, and as said dont be scared but make sure you dont stress / tear the bumper especially at the corners
    Regular Member yadziyad's Avatar
    London
    there 3 torx screws in the arch and 2 above the plate
    Sep 2009
    Glasgow
    thanks for all the info, will attempt again.
  1. Facelift bumper removal
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2012, 16:52
  2. Front bumper removal......pre facelift
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 22:49
  3. facelift rear bumper removal
    By skidmark in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 12:20
  4. Facelift bumper removal?
    By masonic in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2007, 10:36
vectra c facelift rear bumper removal
