Thread: No glow plug light
    May 2008
    Wiltshire
    Default No glow plug light
    1.9 cdti 150 70k on the clock
    have had the car for 1.5 yrs and have never seen the glow plug light! very cold this year -12 one night and still no light, should it light up? i think yes? do you?
    does the light always come on at bulb test ie second click ignition, or does it have to be a cetain temp ie less than 4 degrees?
    i have no spanner light, thank god, had enough of those in the past, so i am guessing that the bulb has gone. The reason i wish to get this sorted is that i am hoping this this bulb will also tell me wh en a dpf regen is occurring. some say it does light up some say no?? does yours on a 04 veccy estate?
    If it doesn't light up but it starts ok why are you worrying about it? Fingers crossed and all that
    The only way to tell if the dpf is on a regen is to watch the instant consumption and see it plumet. You may also hear a different exhaust note and smell burning.
    West
    It could well be the builb has gone... or it could be the coolant sensor giving a false reading
    May 2008
    Wiltshire
    i keep an eye on the instant fuel and it has never shown any signs of doing a regen and have never noticed engine tone. the only time car has done a regen was when put on tech 2.
    i can check bulb, not too difficult, temp censor i will have to look at tis to find it, have also concers regarding water temp, car slow to warm, but its cold out and its a deisel.
    is the bulb suppose to light when ignition on? if not what temp is supposed to activate it if car hasn't been driven
    I doubt its a bulb out as there are not any bulbs in the dask. Just smd's
    May 2008
    Wiltshire
    just had a look at the dash and how to get it out, decided that if car starts then i can live without a bulb woring, just wait 10 secs when cold. if no bulb, thanks for that info, what? car starts ok even -12, couple of turn overs, but hey it was ****** cold!
    How do i prove glow plugs working without swapping for new ones, would really like to know if their ok. i know they get hot, how hot? is it worth turning ignition on, on a cold day and touching them, is it possible to feel the heat. how long do they heat for.
    I am right in saying that all veccy deisels have glow plugs??
    also i take it that glow plugs are not linked in any way to dpf regen are they?
    Nope they are not connected to the regen.
    May 2008
    Wiltshire
    just a long shot LOL. will have to do the touch test.
    any other ideas??
    just rang stealers, they said never heard of smd going.
    car outside temp works ok, if that is the same temp reading that controls glow plugs, or does it come off the water temp guage?
    May 2008
    Wiltshire
    well would you beleive it! lights working now, playing around with the steering cowling must have moved something, light comes on for a second with the ignition, that was 5 degrees. i'll see what it does when below 3.
    cheers all
  1. No Glow Plug Light. Help!
    By M65 in forum Engine & Drivetrain
    Last Post: 4th December 2012, 18:25
  2. Glow plug light
    By mrpoochie01 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 06:37
  3. Glow plug light
    By jacko52 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2010, 21:59
  4. glow plug light
    By gary the box in forum Engine & Drivetrain
    Last Post: 14th December 2009, 21:19
  5. glow plug light
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 17:59
vectra c no glow plug light
vectra c glow plug light not coming on
glow plug light not coming on vectravectra 1.9 cdti no glow plug lightmy glow plug aint lighting up when I put the ignition on on my vectra c 1.9 cdtivauxhall zafira glow plug light not coming onvectra 1.9 cdti glow plug light not on when warmvauxhall zafira 1.9 cdti no coil spring lightglow light doesnt appear on vectra cvauxhall zafira 1.9 cdti glow plug light not coming onvectra c glow plug light not workingastra diesel no glow plug lightvectra c 1.9cdti heater plug tempvectra c 1.9cdti glow plug light not workingvectra c cdti no glow plug lightno coil light cdti150vectra c doesnt have heater plug lightvectra c 1.9cdti glow plug light not coming onvectra c dti no glow plug lighty is my glow plug light not on 1.9 cdtivectra c cdti no coil lightopel corsa glow plug light not coming onvectra c dti glow plug light doesnt allways light up opel omega glow plug lightno glow plug light on signum
