Results 1 to 10 of 18
Thread: Lowering Springs on Facelift CDTi 150 Elite
    Regular Member Lightboy's Avatar
    May 2007
    Reading, UK
    Default Lowering Springs on Facelift CDTi 150 Elite
    Hi All,
    This is all getting a bit too much for my simple mind to work out.. I have a set of Irmy springs that I was going to put on my Vec-C pre-facelift GSi. As I never got round to it and am selling the GSI and now have a facelift Elite I'm wondering if I can save a few quid and fit them onto the new motor (it has 19" Snowflakes on it and sits higher than a JCB so needs to drop a good 3cm to look sensible )
    The Irmy code is 34.03.011 for the front which I think is 1060Kg to 1130Kg
    The Irmy code is 34.04.001 for the back which I think is 980Kg on the rear axle
    If I understand the label on the door pillar correctly the front is 1065Kg and 0985Kg on the back so in theory weight is not a problem?!
    Question now is will they fit?! Part numbers listed for Vec (non-Sport) do not match so I'm thinking not but thought I'd ask before splashing out on something that does or spending ages trying and cocking it up.
    Ideas gratefully recieved
    Wondering lonely as a cloud
    25 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    How much are they a drop from standard, the only issue I think you will have is that the sports suspension is a shorter shock than the elite one and there might be an issue with the shock operation but I think the springs will fit just the shockers might not be appropriate.
    Slough
    82 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    dont know if this is any help m8 but ive a facelift elite with the standard 17in gsi wheels and ive put eibachs springs on and standard shocks and it looks okay.khalid
    May 2007
    Reading, UK
    No idea on how much they lower... The only reference to them (which neilybhoy1888 found for me) is here:
    http://www.irmscher.nl/accessoirepro...06_acc_art.htm
    But the pdf linked at the top of that page says nothing about the part number on the (dutch) website, which seems odd to me.
    http://www.irmscher.nl/bestanden/pdf...ra_0704_GB.pdf
    I don't want to knacker the shocks so maybe best to fork out for a set of Eibachs I guess - just wanted one last shot at figuring out if these would do the job or not.
    May 2007
    Reading, UK
    Quote Originally Posted by happypostie View Post
    Which ones did you get mate? Do you have a pic?
    There appears to be two codes on the Eibach website...
    Product Code : E10-65-007-01-22 Quick Code : A58C4
    and
    Product Code : E10-65-007-02-22 Quick Code : A58C5
    No idea what the difference is..?
    25 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I am not saying they won't work but if they list seperate springs for the different suspension then there is a potential issue, lowering springs will go on the shocks but who knows how long they last and Eibachs just list lowering springs don't they, the Irmscher kit is a bit more comprehensive and they should know if anyone does.
    May 2007
    Reading, UK
    I've found (from the forum archives) that they (the irmy ones) are the same as the Eibach ones - exactly the same - according to the to TV docs...
    Irmy 34-03-011 and 34-04-001
    http://www.irmscher.de/abe/de/7_34_0...5-37_40-42.pdf
    and
    Eibach E10-65-007-02-22 which is the part number (according to LMF) for springs for the 1.9CDTi facelift, they are stamped as 11-65-007-02-VA as can be seen in here:
    http://www.koenigseder.at/uploads/tx...Katalog_01.pdf (to get from part to stamp no.)
    and if you then check the TV spec for that stamp from here:
    http://performance-suspension.eibach...&field=abe_www
    ...and compare the TV spec for each between irmy and eibach, they are identical!
    Phew... roll on the weekend, I hope fitting is easier than this! ;-)
    West
    Quote Originally Posted by Lightboy View Post
    Hi All,
    If they are a 30mm drop & As the axle weights are compatible you should have no probs with them on the standard shocks... any lower than -30mm & you need to be changing the shocker for a shorter one.
    hth
    May 2007
    Reading, UK
    It appears as though they are a 30mm drop, I guess (apart from the TV docs which suggest they are comparable) there is no other way of telling without fitting them?!
    Thanks for the advice guys, appreciate it.
    hth
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The same PI springs for the GSi 3.2 fit the 2.2DTi and 1.9CDTi's too, so they go on no problem mate - I know a bit late, but a further confirmation.
  1. springs and shocks for a facelift elite?
    By toast in forum Handling & Braking
    Last Post: 24th November 2011, 22:02
  2. 1.9 cdti lowering springs
    By Deacon in forum Handling & Braking
    Last Post: 6th October 2010, 20:16
  3. pre facelift lowering springs
    By booker413 in forum Handling & Braking
    Last Post: 19th June 2010, 19:52
  4. PI Lowering springs CDTi 150 (possibly more)
    By RobW in forum Parts for sale
    Last Post: 1st November 2009, 17:20
  5. 3.0 cdti sri lowering springs?
    By rigga70 in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2009, 22:08
