Thread: very strange consumption/smooth acceleration
    scarborough
    Default very strange consumption/smooth acceleration
    not had the car long but the car takes a long time to get to temp (although i have only seen it get to 80)
    when it does finally get some heat into the engine the instant consumption goes to 1mpg at idle
    at the same time i loose my smooth acceleration and the fuel consumption drops through the roof when driving
    turned the engine off while i was having this problem and it went away when i restarted about 1 minute later.
    anyone else had anything similar??
    the car is a 2007 1.9cdti signum
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The diesel particlate filter uses diesel to clean itself when the conditions are right and this drops the fuel consumption down considerably it returns to normal when you switch off as the engine needs to run to do it or the cycle is completed and switched off by the ECU.
    scarborough
    thank god for that!
    i should stop paying so much attention to mpg and just enjoy the car!
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    All the diesels with DPF do it watch it on a long run and all will come good.
  1. smooth swift
    By Swedge in forum Detailing and Car Care Discussion
    Last Post: 9th December 2012, 18:34
  2. How to get a smooth ride?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2012, 11:26
  3. Strange noise under acceleration 1.5-2.5k revs?
    By Thom in forum Engine & Drivetrain
    Last Post: 20th September 2011, 14:52
  4. hammerite smooth
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 13:05
  5. Strange fuel consumption problem?
    By Vectra Singh in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2007, 15:47
