Results 1 to 2 of 2
Thread: engine temp
    May 2008
    Wiltshire
    Default engine temp
    04 1.9 cdti 150
    having read lots of posts here about engine temp cant seem to get a definite answer, its cold out i know but my deisel is running at a very low temp, i rn abbout 7 miles to work in the morning and the guage hardly moves, heater get warm after a while. surely car should heat up and stay at a set temp? what temp is that? I supose the bst test would be to start car from cold and hold the radiator top and it should stay cold until car temp guage is hot, yes?
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you are only going 7 miles it probably won't move mine goes to approx 78 - 80 degrees at the moment and in the summer 85 degrees and I travel 60 - 70 miles to work but the cold air will keep the temperature down if you want to test it take it for a run to get it warm and then stop and let it tick over for 15-20 mins and then see what the temperature reads if it is still not moving change the thermostat but test it first as they ain't cheap and it takes about an hour to do.
  1. what should teh engine temp be in 1.9 150
    By kirky2k4 in forum Engine & Drivetrain
    Last Post: 26th January 2011, 22:16
  2. Engine Temp.....
    By skip85 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 01:51
  3. Engine Temp
    By bigmac in forum Engine & Drivetrain
    Last Post: 17th May 2010, 20:36
  4. Engine temp vvt
    By shadyone in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 19:11
  5. engine temp.
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 21st October 2009, 19:56
