Results 1 to 3 of 3
Thread: running after new inlet manifold
    May 2008
    Wiltshire
    Default running after new inlet manifold
    1.9cdti 150, end of last year had new inlet manifold due to swirl valves linage u/s. initial prob was that em light on and garage read fault codes as dpf over fill, they also noticed manifold prob.
    new manifold fitted, tech 2 on dpf, then got car back.
    Question, i feel that car is slightly sluggish from the off, geting 39 m/gall not 42 as before the work. this may be due to winter air and electrics running more, heaters etc??
    I asked the garage when they fitted manifold did they need a new motor that turns the swirl valves or did it need any setting up, they said no, is this right?
    I have never seen my car do a dpr regen, car runs cold most of the time, i think usual on deisels? garage did tech 2 nov 09 haven't noticed regen since then, took car down motorway saturday about 40 miles keeping speed at about 70 ish, so revs high enough, had trip comp on miles per gal instant readout so see if car did a regen, nothing. I am concerned that dpf will block again, if car does regen on tech 2 does that mean car is working ok??
    Jul 2009
    N. Ireland
    Quote Originally Posted by iasha View Post
    I was told the same thing last week mate. Had a new Inlet fitted last Wed and was told 100% i didnt need to change the motor. The head Vx
    mechanic told me he'd never fitted a new motor with the Inlet manifold.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I had new manifold & egr fitted just before Xmas under extended warranty & after they'd finished I found they didn't change the actuator either. I showed the Service Manager the Pierburg pdf which he in turn quoted to Vx warranty, who then authorised the additional work & parts - can't imagine Vx agreeing to all the extra work & cost if they could get away with it
  1. Inlet Manifold
    By Quirrel in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 12:59
  2. inlet manifold
    By chay6684 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 23:24
  3. Inlet manifold
    By vectra66 in forum Engine & Drivetrain
    Last Post: 20th June 2011, 23:00
  4. inlet manifold
    By sig num in forum Engine & Drivetrain
    Last Post: 5th June 2010, 23:10
  5. inlet manifold
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 28th February 2010, 02:03
