Results 1 to 10 of 18
Thread: anyone know how to tap into cig lighter circuit?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default anyone know how to tap into cig lighter circuit?
    as above...left me haynes and other papers at the mothers, can I tap into it from under the bonnet fuses instead of dragging wires through the cabin? If so which one is it...thanks guys
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    This is from the handbook and it comes from the fuse box in the front passenger side.
    248 Self-help, vehicle care
    Fuses and the most important
    circuits they protect
    Fusebox in passenger compartment
    The fusebox is on the left, on the outside of
    the instrument panel. Open door.
    Disengage cover by p ulling firmly and
    remove.
    Spare fuses, fuse extractor – see page 246.
    Some circuits may be protected by several
    fuses.
    No. Circuit Rating
    1
    Infotainment system, radio
    transport fuse
    20 A
    2
    Interior fan, heating, air
    conditioning system
    7.5 A
    3
    Sunroof 20 A
    4
    5
    Door module control unit 7.5 A
    6
    Brake light 7.5 A
    7
    Bodywork module control
    unit
    30 A
    8
    Front passenger’s door
    module control unit
    30 A
    9
    Central control unit 7.5 A
    No. Circuit Rating
    10
    Steering column module
    control unit
    7.5 A
    11
    Diagnostics p lug 7.5 A
    12
    Battery overload protection 10 A
    13
    14
    15
    Door module control unit 30 A
    16
    17
    instruments, information
    display
    15 A
    18
    19
    20
    Yaw rate sensor (ESP®Plus) 7.5 A
    21
    22
    Cigarette lighter 30 A
    23
    Interior fan, air conditioning,
    Electronic Clim ate Control
    30 A
    40 A
    24
    25
    Heating, air conditioning
    system
    7.5 A
    26
    Instruments, information
    display
    7.5 A
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I assume that you want an ignition live point...
    If so, there are some in the UEC (under bonnet fuse board).
    some technical person will come along soon and tell you which fuse / relay point to take your feed from.
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    after one for when the sidelights are switched on it becomes live ...going to do a bit modding for some led sidelights
    cheers paul
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    There is a light feed from the bcm, in the back of the glove box...
    Just for driving the cig lighter back-lighting circuit.
    The BCM has 78 pins in the main connector.
    You would require pin number - 74...grey/yellow wire
    hope that helps....note it will not affect the can-bus, and will not need tech 2.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    How you going to overcome the standard bulbs holders and wiring not being used? it will still need to be connected or a bulb in to stop bulb warnings etc wouldn't it...
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    yeah m8 going to tape old sidelights up with bulbs in and use a custom feed from the cig lighter circuit to some wires with donor bulb holders on for the led bulbs...shouldn't get any strobing then (he hopes)lol
    Quote Originally Posted by Robsey View Post
    thanks m8 will have a looksee
    slough
    hi mr if you pullout your ash tray and look down the hole there are two other wires in there taped up on some models and on others they are used to light up a bulb in the ash tray they are there have a realy good look and you will find them and they are fused.... hippo out..........
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Very good, just remember you've taped the old ones up, because in 6 months you might be stood at the front of your car scratching your head because it says a side light is out but there both still lit
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Just a thought, with the old holders can you just put some wire in there? or would it need to be a bulb??
    My granddad on my 1st car bodged my fan that way so it kicked in when the engine was running as it was temperamental so kept over heating... would it work with the bulbs and warning system?...
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. fan relay circuit 3
    By cruicky27 in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 13:26
  3. Lap of new Silverstone circuit
    By Daywalker in forum Motorsport / Formula 1 etc. chat
    Last Post: 28th May 2010, 12:56
  4. Croft Circuit
    By Dunc in forum The 'Off Topic' room
    Last Post: 31st July 2008, 22:14
vectra c cig lighter fuse
