Results 1 to 10 of 15
Thread: Cd 30
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Default Cd 30
    Hi , just bought my first vectra and need some advice .
    It's ex cop and the prev owner has put in a blank surround and fitted a single din aftermarket stereo.
    This is pants and I can't use the steering control or access the computer.
    I have seen several original cd30 units on eBay and need to know if the retrofit is simple, will it need to be unlocked/ paired with the car. Also they all seem to be the same colour , is this the case?
    Pete
    Jan 2010
    Blackburn
    Putting brain in gear its a 2005 m/y so should I be looking at CD 70 s ?
    (just got it and am finding my feet with it)
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Whats your current radio?
    Jan 2010
    Blackburn
    Mutant mt2200bt. With remote. I'm not great with ice or auto electrics
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    CD30 is the basic late 2004 onward radio...usually comes with a basic screen with clock setting buttons. This is the TID screen.
    It will not have computer functions, but will have CD and radio and steering wheel controls where fitted..
    You would ideally need the radio to be Tech 2 divorced from the previous car.
    Then it "should" be plug and play...fit and plug in the screen and head-unit...assuming that who-ever fitted the radio didn't butcher the wiring.
    Once the display and head unit have been fitted, then they will need tech 2 programming to marry them into the car and to each other.
    If you want board computer (BC) functions, then you will need a graphic info display rather than the basic Triple Info Display (TID)
    Jan 2010
    Blackburn
    Great , thanks for that. I'm happy with the tid screen I just want the dash back looking standard and be able to get the date and time right !
    Is tech 2 a vx dealer job or are there independant sources to get a unit I buy divorced and working in my car ?
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you can get some car audio places to tech2 it if you need to.. If you want a cd30 and a GID including screen/vent surround with the code send me a pm... i took it out of my car, it did not need to be divorced... just the screen and headunit are 'married' to each other
    Quote Originally Posted by Robsey View Post
    It will not have computer functions, but will have CD and radio and steering wheel controls where fitted..If you want board computer (BC) functions, then you will need a graphic info display rather than the basic Triple Info Display (TID)
    Mine is a CD30 and has all computer functions displayed on the basic screen
    However the screen I have is slightly different from the base models
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yep, sounds like someone has done the GID upgrade for you.
    GID will be orange display, but with no clock buttons.
    You will set the time via the settings menu instead, or via the steering wheel controls (if fitted) as there are no clock buttons on the screen bezel.
    All the Vectras I looked at, 2004/2005 SRI models had the same setup (as above)
