Thread: egr blanking plate
    Sep 2009
    newcastle
    Default egr blanking plate
    i am after some egr blanking plates for my veccy anyone
    know where to buy any
    cheers
    Bristol
    Vehicle : CDTI 150
    What engine?
    Sep 2009
    newcastle
    1.9cdti (120)
    Bristol
    Vehicle : CDTI 150
    There isn't one.
    If you want to make one remove the EGR and use the EGR to manifold gasket as a template to make a blank out of a coke can or similar.
    However you will get thye MIL lamp on as you cant code the EGR out.
    If you drill two 6mm holes in the 'blank' it will allow enough gas through to keep the ECU happy and prevent a lot of crud entering your engine, the crud will build up in the EGR which will need a periodic clean.
    Sep 2009
    newcastle
    Default egr blank
    hello
    does this mean that the egr is still in operation because
    i might do my mates as he thinks his egr is dodgy i think his plunger in his egr is stuck open or sticky we were going to blank it just to save doing the mod but if it is still operational theres no point because he will
    still have same probs.
    cheers les
    West
    will the fiat gasket fit... it fits the 16v, maybe it's worth a look http://www.vectra-c.com/forum/showth...blanking+plate
  1. For Sale: DTi EGR Blanking Plate
    By TonyP2020 in forum Parts for sale
    Last Post: 8th November 2012, 00:10
  2. Egr blanking plate
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th September 2011, 20:49
  3. Egr blanking plate
    By baz_cdti_sri_150 in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:51
  4. blanking plate
    By lordreeson in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 12:59
