Results 1 to 10 of 15
Thread: Vectra 1.9CDTI Overheating
    Regular Member brad69bj's Avatar
    Jun 2009
    Leeds
    Default Vectra 1.9CDTI Overheating
    Hi, can anyone help plz? Problem is, I topped up the cooling system with 500ml of antifreeze on Sunday, all I did was pour it in the header bottle. No pipes were touched. When I started to use the car on Monday it was overheating and the heater was blowing cold? Rad fans are kicking in and trying to cool rad down but it is already cold?? It doesnt seem to be circulating..
    Do I go down the change thermostat line?, or look to the water pump? There is no noise coming from the water pump. It doesnt appear to be an air lock as I have since Bled the system and Heater matrix pipes.. The Thermostat is a pig to change because of the bracket connected to the bottom nut.
    Any Ideas - Thanks Brad
    Jan 2010
    Yorkshire
    I would go for the thermostat first as the heater is cold, it sounds like the thermostat is sticking or there is a blockage of somekind. Only what id do tho, im sure someone with abit more knowledge will be along soon
    If you do change the thermostat and its a 120 asit sounds from your description of the thermostat bracket, dont forget the 2 bolts on the back of the engine to remove the heat exchanger
    Jun 2009
    Leeds
    Thanks mate, Yeah I know the 2 bolts you mean. It was a bit awkward to change but I replaced the thermostat with a new part from the stealers, 57. Anyway it wasnt that!.
    Then I removed the timing belt to get to the water pump and when I removed the pump it became obvious what was wrong!! The Impeller or whatever you might want to call it, had come off the back of the pump!! Another 42 from the stealers. The car is a 56 reg 3yrs 3mnths old with 65k on it.
    I went for the Thermostat first cos the water pump wasnt making any noise to make me think that was the problem.
    mars
    brad69bj im in the same boat m8. just changed thermostat on my 08 1.9 cdi this morning which cost around 48 and still over heating with know hot air coming out the dash. Sounds like the water pump looks like i will have to book it into the vauxhall and pay a fortune i don not have.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    With the engine running, even from cold, you should see coolant returning to the header tank from the small pipe, this is the bypass until the thermostat opens. It sounds like the impeller has fallen off the water pump. I'm sure MCD had this a few weeks back, ill see if I can find the thread.
    mars
    Thanks DasArab,.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    ewan is this the thread
    http://www.vectra-c.com/forum/showth...cd+overheating
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Aye it is mate, but I noticed he never posted if that was the cause of his problem. Ill PM him and see if he can help.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by brad69bj View Post
    have a read
    http://www.vectra-c.com/forum/showth...rubber%20smell
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Reply from MCD already.
    Hi Ewan,Yes it was the water pump! Turned out it was the blades slipping on the splines on the inside... So not noticable externally!Typically, the splines were nylon... The new part is steel! Typical vauxhall! All good. Ow and always doubted the heater matrix.. Why would that fail on a modern car?Hope this helps?Mike
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. Vectra C Turbo overheating
    By SriTurbo1 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 08:03
  4. Vectra overheating to 100
    By manugasau in forum Engine & Drivetrain
    Last Post: 11th April 2011, 18:15
  5. Vectra losing power & overheating
    By sr310583 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd April 2010, 10:58
vectra 1.9 cdti overheating
vauxhall vectra overheating
vauxhall signum overheating
vectra c overheating problem
vectra v6 cdti engine hot heater cold
why does vectra overheat
03 opel vectra overheating
opel vectra 1.9 cdti overheat
Vectra 2008 diesel over heating
vauxhall vectra overheating problems
vectra 2004 1.9cdi temperature sensor water cooling
1.9cdti přehřívá
1.9 cdti circulation pump
Vectra 1.9 cdti engine is heating
what can cause a vauxhall vectra c to overheat
vauxhall vectra overheating fix
overheating vectra 1.9 diesel
opel 1.9 cdti overheat
vecta c 1.9cdti cambelt noise overheating
water pump replacement vectra 1.9 diesel
vectra no heating and engine overheating
vectra c new water pump and thermostat still overheating
vauxhall 1.9 cdti running hot
vectra c overheating damage
how do you know when you need to change your thermostat on vauxhall vectra 1.9cdti
