Thread: new alternator but still battery light for 2mins?
    Regular Member Craig1985's Avatar
    harwich essex
    Default new alternator but still battery light for 2mins?
    hi after my battery light comin on along with my abs/tc/esp light i changed my alternator.
    I changed it and the battery voltage soon went op to 14v but every moring my battery light comes back on for 2 mins then goes? only does it first start onf the day?
    dtc is p0621-02?
    Battery voltage is 12.5v before the first start and then 11v. the battery doest seem to charge straight away but after a few minutes of driving and the battery will quicky rise to 14v? does this sound like a faulty alternator again? its a lucas re-manufact.
    I thinkforgot to disconect the battery when i took the old alternator off and got a spark from some where? (had been a long day) could this have damaged my ecu/cim?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    P0621 generator control lamp arrangement dysfunction IPC (instrument) C-021
    Faulty clocks maybe ?
    Irmscher Insignia CDTI 130
    harwich essex
    faulty clocks? that would be the iceing on the cake!
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Not sure but IPC is instruments which is Clocks,wait till some one else post before you take my advise
    harwich essex
    its going in for a startor motor at dealers soon so ill get them to investigate if i cant sort it, but would like to sort it out my self first really?
    harwich essex
    anyone else have any ideas what p0621 Generator Lamp "L" Control Circuit Malfunction
    is and a possible fix? after reading old threads doesnt look like anyone knows
    leeds
    Hi Craig,
    This happens if you fit the wrong alternator. On older types the L circuit was simply connected straight to the warning lamp. On a Canbus car it goes to the ECU which controls the warning light. I am guessing your alternator does not comply with Canbus.
    This is a known problem when fitting an aftermarket alternator. Not all of them are correctly listed!
    Hope this helps
    David.
    harwich essex
    Quote Originally Posted by davidj387 View Post
    Hi Craig,
    Hope this helps
    David.
    it doesnt do it all the time tho?
    Regular Member JonV6's Avatar
    Cardiff
    Quote Originally Posted by Craig1985 View Post
    That's CANBUS for you, intermittent city!!!
    harwich essex
    are alternators connected to the canbus sytem? i only have a thick brown and a thin blue? im getting 14.2 from the blue?
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Red Battery Light: Suspected Failed Alternator - DIY or Garage?
    By samlawrence in forum Engine & Drivetrain
    Last Post: 10th August 2011, 20:27
  4. battery light on, alternator not charging, aarggh!!
    By valvelift in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 17:33
  5. Alternator/Battery Dash Warning Light
    By cavester in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2011, 08:24
changed altenator on vectra but battery light is still on
vauxhall insignia battery light on
Generator Lamp L Control Circuit Malfunction
p0621-02 generator lamp l control circuit malfunction
vectra c battery light on
vauxhall insignia changed alternator but battery light comes on
2006 vectra generator lamp l control circuit malfunction ipc (instrument) c-021
Generator Lamp L Control Circuit Malfunction IPC (Instrument) C-021
generator control lamp arrangement dysfunction ipc
alternator malfunction lamp l
insigna alternater light
https:www.vectra-c.comforumshowthread.php100926-new-alternator-but-still-battery-light-for-2mins
2010 vauxhall insignia 2.0 cdti alternator charging but battery light on
vectra c dti battery light on
