Thread: loss of power, revs bouncing
    Regular Member eaglepva's Avatar
    Up North
    Default loss of power, revs bouncing
    My car been playing up again, driving along and all of a sudden you will lose power and the revs start to drop, put my foot to the floor to try and accelerate and their no power then all of a sudden the power comes back, but while losing power the revs are bouncing up and down. Their is no warning lights or anything showing, but when the power comes back and i rev it a bit loads of black smoke out the back, thick sooty smoke. Forgot to mention the car is a 2.0DTi with 79k on the clock,
    Any help much appreciated on this as it doing my head in.
    Aug 2009
    North East
    Can't help, but mine is having this problem too. Signum 2,0 DTI. Occasionally goes into limp home and spanner light comes on. I took it to Vauxhall dealers and the said throttle sensor and fuel pump (ecu) needs replacing. Quoted me £3000!!!! I'm getting a second opinion and will post my findings.
    Forgot to mention... rev counted occasionally bounces up and down when idling.
    All problems intermittent, mostly the car drives fine.
    R
    Nottinghamshire
    Quote Originally Posted by Whirlwindgirly View Post
    R
    Let us know what your second opinion says. If they agree with the dealer, then I'd probably have just the throttle body changed first (it may be that the throttle valve is sticking and/or the throttle valve position sensor - if your car has one - is faulty). This is much cheaper than the fuel pump and will save you having to replace the pump as well if the new throttle body alone fixes the problem.
    Regular Member muzmayhem's Avatar
    Jan 2010
    North Angus, Scotland
    Iv'e had the same problem with my 2.2 DTi Signum. Had it in the garage last week and they fitted a new throttle body on the warranty. Got it back yesterday and it seems okay. Time will tell.
  1. Loss of power - high revs
    By ac14 in forum Engine & Drivetrain
    Last Post: 19th March 2012, 22:11
  2. Exhaust emission light and loss of power below 2000 revs
    By craigb in forum Engine & Drivetrain
    Last Post: 14th March 2011, 15:08
  3. Spanner light and loss of power at low revs
    By Marky in forum Engine & Drivetrain
    Last Post: 29th April 2010, 16:34
  4. Can you Help ~ Loss of Power, High Revs
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:23
  5. 1.9 cdti power loss at low revs
    By topdogs in forum Engine & Drivetrain
    Last Post: 27th January 2008, 03:56
bouncy revs on my vauxhall
vauxhall insignia revs bounce
