Thread: oil extractor
    Edinburgh
    Default oil extractor
    Anyone used on on their Veccy?
    My sump plug is stuck and rounded. Not sure if I want to risk damaging the sump cause it looks like a right pain to change.
    Got a 1.9 CDTi 150
    I rounded off the the edges of the hex on my sump plug as well when I last changed the oil on my cdti 150 (the metal is about as strong as toffee). I was quite amazed to find that a couple of taps on the outer edge of the plug with a small hammer and chisel loosened it easily. If you do this and fit a new plug I would advise that in future you always use a six sided socket rather than a multi point one to remove the plug.
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Quote Originally Posted by Big Knox View Post
    Got a 1.9 CDTi 150
    Get a hacksaw and cut a small groove/slot across the sump plug and use a screwdriver to undo it or as above gently tap the slot you cut with a hammer and chisel. I had the same problem as my plug was overtightened and I sheared off the Torx bit in it!
    Edinburgh
    Quote Originally Posted by Rapala View Post
    yeah, I tried it with a chisel but still nothing. Might have to drill it and use an extractor. Will definitely be using a 6 sided socket next time.
    I even had a ring spanner of a smaller size hammered onto it and it just chewed it as well. Like you say, the metal on the sump plug is really soft
  1. oil extractor
    By kev77 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 22:49
  2. oil extractor
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 00:02
  3. Using an oil extractor
    By Middo in forum Engine & Drivetrain
    Last Post: 25th June 2009, 20:15
  4. Oil extractor. Pela 6000
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2009, 22:01
  5. Bathroom Extractor Fan
    By julian924s in forum The 'Off Topic' room
    Last Post: 31st December 2008, 10:23
