Results 1 to 10 of 18
Thread: Excess smoke/poor 1st gear pull off
    In a nice car, in work
    Unhappy Excess smoke/poor 1st gear pull off
    My 56 plate Vectra c 1.9 CDTI Sri has now done 92000 miles (FSH). Recently the engine management light flashed on and off intermitently. The power was greatly reduced and the car appeared to be in a safe type mode. The light has since remained on, but the power has returned in all gears except for 1st. There is also a lot of smoke from the exhaust when the throttle is pressed. Pulling off is becoming an issue especially when the engine is cold.
    Is this a common problem, or any suggestions greatly recieved?
    May 2007
    GLASGOW
    Is your swirl bar off? If u dont know what it is do a search on here. Am havin similar symptoms and mine is off
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    is it a 150ps model?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Could be EGR too (120 or 150).... hopefully this is it as its a damn sight cheaper then a new inlet manifold (150 only)
    Its on a 120. Will look at a swirl bar now.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Dean View Post
    It won't have one, its likely to be the EGR valve.
    Looking at the 'how 2' info, would a good clean get it working ok? or do you think it is a problem with the inlet manifold?
    Lancashire
    Trim : XP1
    Mileage : 66000
    I think a good clean would sort it mate, a few have used that 10K Boost stuff to "de-coke" it, but I would start with cleaning it.
    Sorry to be nieve, but is the boost sensor the same as an EGR valve? and what does EGR stand for?
    Lancashire
    Trim : XP1
    Mileage : 66000
    No, the EGR is an Exhaust Gas Recirculation valve which re-directs exhaust gasses back into the intake system.
    Have a look at this thread for some pics of it from a 120 CDTi for reference... http://www.vectra-c.com/forum/showthread.php?t=100610
  1. 6 th gear pull
    By ronaldodg9 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 21:22
  2. Poor Starting & Thick White Smoke (2.0DTI)
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 4th June 2012, 13:47
  3. cold start smoke and poor running engine
    By Tredici in forum Engine & Drivetrain
    Last Post: 16th January 2012, 08:40
  4. top gear tonight 8pm poor james may lol
    By hoochydady in forum General Chat
    Last Post: 27th December 2010, 19:13
  5. Veccy 120 CDTi Poor Gear change
    By ali06 in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 22:08
