Results 1 to 10 of 20
Thread: disable egr with op com
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default disable egr with op com
    can you disable the egr using op com?? or do you have to use tech 2 it would be handy to do this i am currently using a blanking plate with 2 5mm holes and this is working fine with no lights but i would rather blank it off complete
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Might sound a bit daft, and i'm not a genius on cars, but would disabling the EGR valve not decrease MPG, and would you not fail emissions test on MOT?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Danialj32 View Post
    No and no, if yours is a 2.2 petrol yours is the only engine in the Vec C line up where all you have to do is blank it, no software upgrade needed. And mine passed its MOT on saturday and my EGR is blanked.
    kings lynn, norfolk
    def not fail emissions as diesels have a smoke test and not emissions on my mondeo i had i had egr valve blanked completly and had decat and passed with flying colours mpg was fine too
    back to the question can you disable egr with op com or has it got to be tech 2 also would the stealers do it for you if you ask???
    Sep 2009
    Warrington
    Sorry to hi-jack the thread lol, but what gains would you see in blanking the EGR?
    kings lynn, norfolk
    you dont get exhaust gasses back in your inlet manifold which clogs up your manifold and swirl flaps, you have cleaner and cooler air which does not choke your car and less problems with egr sticking and it just runs better with it blanked. its only there to meet euro 3 emissions regs and in my eyes they are a waste of time and cause to much bother when americans are driving around in there big v8s
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No gains really mate, unless you really go to town in the intake. The same engine in the US doesn't even have the EGR fitted. If you have a look into your inlet manifold it will be full of oil and soot, combined they really choke the intake up. Eliminating the zorst gassed can only be good. The EGR is only to meet Euro 4 regs from factory, as soon as it leaves the factory its not legally needed.
    kings lynn, norfolk
    can any one help lol can you disable the egr valve through op com or does it need to be done by tech 2 at the dealers????
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by winnie2457 View Post
    Regal do it as part of there map, might be worth speaking to them?
    Regular Member Fash's Avatar
    Doncaster
    Can you blank the egr valve on the cdti 150 to save any of the hassles of it c**king up ??
  1. Disable alarm?
    By TimK in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2012, 00:33
  2. egr disable 2L ??
    By dc6839 in forum Engine & Drivetrain
    Last Post: 22nd July 2011, 10:51
  3. disable egr 1.9
    By exvectra in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2010, 17:32
  4. Possible to disable ABS?
    By MarkySparky in forum Suspension, Wheels & Brakes
    Last Post: 24th December 2009, 02:06
opcom egr disable
opcom egr off
opcom egr delete
disable egr opcom
vectra c opcom
opcom disable egr
egr test opcom
op com egr off
op-com cdti egr solenoid testtest egr with opcomvaux com egr disableopcom egr how todisable.egr opcomcan you delete the egr on a saab 9-3 with an op-comdelete egr with op-comop-com disable egrvectra c wycięcie egr opcomopcom egr solenoid testopcom disable dpfegr opcomegr 1.9cdti uitschakelen op-comegr value opcomz18xe opcom egr deleteopcom diagnostics Vauxhall Zafira egrreduce egr opcom
