Results 1 to 10 of 16
Thread: headlight flicker
    staffordshire
    confused headlight flicker
    I have a '06 1.8 SRI, with 28,000 on the clock. I love the thing to bits ! But for rome reason when the steering is pointing straight and just turned slightly from side to side the headlights dim for a fraction of a second then back to normal, causing a slight flickering, They work perfectly at all other times. Does anyone know what this is or is it normal, should i be worried something will go bang later on !?
    PS great site and so far i have found loads of useful info on here.
    Regular Member madman's Avatar
    nottm
    i noticed this on my 04 2.0dti. the power steering pump is electric. mine does it at a standstill and is just the power steering pump pulling power from the electrics of the engine. nowt to worry about
    May 2007
    West Yorkshire
    both my Vecs have done it, and ones @ work I have driven do it, I suspect it's a design flaw. Most cars will do it when both electric windows are pressed it's just the load on the alternator.
    Mileage : 000
    The thing is you have a power steering pump that is both electrical and "numatic" and when you turn the steering there is an enormous power drain on the electrics. That is why the headlights dim. I know mine does it too. I also founf that when the TC cut in when we had the snow the "info" screen would dim whilst the TC was stopping the wheels from spinning.
    Regular Member sristeven1's Avatar
    wirral
    but why is this i photoshop section lol
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Loads of posts on here on this subject...a well known 'characteristic/quirk' with the Vectra C's with the electro/hydraulic power steering GM invented....I've just put on a higher capacity battery because of a discharging battery & mentioned in threads on Battery Issues....no difference still flicker.. alternator is rated a 120amps...Think it was Ste who measured the current draw from the alternator with practically electrical consumer on the car ON but without the power steering being used & measured around 100amps-1200watt at least..have you tried turning the steering wheel without power steering....Schwartzengger springs to mind....
    Tends to be when you are turning the wheel at low engine revs that it's more noticable...I've learned to live with it as have many others....cheers
    staffordshire
    Default thank you
    A big 'thank you' to all that replied, i can now relax and stop boring my other half about it !? A great site, keep up the good work
    Newbury
    I noticed this exact issue this evening (not had car long at all) as it was my first time driving at night in the Vec. I have seen something similar i.e. elec window effect. Anyway so I put some revs down and moved the wheel, but the lights still flickered. I thought by revving the engine a bit it would give more power (Im no mechanic), oh well, as above, just have to live with it.
    I wonder if it is noticeable whilst driving along?
    Quote Originally Posted by danno View Post
    Clearly not as you haven't noticed
  1. headlights flicker on pull away
    By andy_richmond in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 23:13
  2. Poor MPG and light flicker
    By vectra_driver in forum Engine & Drivetrain
    Last Post: 13th February 2012, 19:02
  3. Sidelight flicker
    By dhwigston in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2010, 12:51
  4. headlight flicker
    Last Post: 1st November 2009, 21:52
  5. headlight flicker
    By mikeopolo in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 22:48
would a bigger battery stop my headlights flickering on my 07 vectra sri
vauxhall vectra c 05 headlights keep flickering
Vauxhall dim headlighs and no power steering
vectra 1.8 vvt power steering makes lights flicker
vectra c lights dim when steering
vauxhall vectra c headlights dim down turning steering wheel
is it normal for my headlights to flicker on my vectra sri 07
vectra headlight flicker
vectra c flickering headlights
