Results 1 to 10 of 17
Thread: Strange rattle from engine.
    Regular Member suggs1971's Avatar
    east cleveland
    Default Strange rattle from engine.
    Right here goes. I own a 52 reg veccy c 2.0 dti. Ive had the car for about a year, when first started and driving steady my car sounds ok, if i give it a bit more revs then there is a louder rattle, my car has done this since ive owned it, once run for a while the rattle goes. Over the last couple of days the rattle is always there cold and hot engine at low revs 2000 -3000 revs approx. If driven gently the rattle isnt there but is with a bit more power. My car when stationary will rev fine at all revs, no rattles, but under load the rattle appears. One thing i have noticed the miles per gallon have dropped over the past month, i was getting 43 to 44 mpg over the year ive owned the car it has now dropped to 41 mpg so there seems to be a problem somewhere. There is no engine management light on, temperature is fine, starts fine and accelerates well. Any suggestions would be appreciated.
    Jan 2010
    croston lancashire
    mine was doing this and the other day i went to shut the door and heard it and went aaaa hang on , so i got girlfriend to slam the door and i looked under neath and was the heatshield . just something to check
    Jan 2010
    croston lancashire
    could also be your flexi pipe broke that makes a noise and can give you naff mpg
    Oct 2009
    Teesside
    Does it do it when the clutch is fully depressed?
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    Quote Originally Posted by robert_dale View Post
    hey i have noticed that on mine just in 1st and second gear if i press the clutch in and let it out slowly it makes a slight rattling noise what cld it be
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    if it is clutch related, then it is time to get a bank loan.
    Dual mass fly-wheel and clutch replacement may be looming ahead.
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Quote Originally Posted by dannyjpuk View Post
    Sounds like you Dual Mass Flywheel mate
    Jan 2010
    northumberland
    **** i hope not its only done 12,500 miles how does the flywheel break ect
    east cleveland
    Well i put my veccy into vauxhall on wednesday. They took it for a drive, put it on tech 2 (had no engine management light on), Been informed to have a pressure test done on the injectors. I was going to get the injector seals replaced but the garage where i get a few jobs done said would be better to replace the injectors, would this be right? Also i rang vauxhall for a price on the front coil spring insulators, they said they should go on the top and not the bottom, any help would be appreciated.
    east cleveland
    Right ive just priced up the injectors £100 + each. Im sure its not the injectors themselves as ive read some of the forums with the problem of rough starting sometimes etc. Leakoff pipes were done last year, car has done 140,000 miles, once started it runs fine with good acceleration so as said in the forums injector seals need replacing i think. I rang vauxhall and they said there are 3 seals, does anyone know which seal i would need, vauxhall said it probably would be the bottom one? quoted £1.33 each.
  1. Strange Rattle from Corsa Engine
    By nibblitz in forum Comedy & Humour
    Last Post: 7th June 2011, 21:20
  2. strange noise and rattle..
    By jezz77 in forum Engine & Drivetrain
    Last Post: 17th September 2010, 21:56
  3. dmf rattle....very strange?
    By big rich in forum Engine & Drivetrain
    Last Post: 26th March 2010, 22:00
  4. Strange rattle from gearbox. 3.2 V6
    By mammix2 in forum Engine & Drivetrain
    Last Post: 28th August 2008, 21:00
  5. Strange rattle sound on 3,000 rpm.
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 29th February 2008, 01:44
