Results 1 to 10 of 11
Thread: hard to start
    Jun 2006
    Plymouth
    Default hard to start
    Hi People. Just joined recently. Just bought a 2003 52 plate 2.2 dti sxi. when i leave the car parked face up a hill overnight its hard to start the next day. had to roll it onto a flat surface to get it started. its turning over but takes a few mins to start up. seems like no fuel getting to the engine. Has anyone encountered this problem before. Cars still under warranty.
    Feb 2006
    Guttedsville
    Sounds like the fuel return pipes from the Injectors. About a fiver each I think. Not done this myself ( yet ) so would be interested to hear if this solves it.
    Mackie, take it back to garage as its under warranty......why pay yourself mate..
    Follow the words of AF mate.. take it back in and tell them the fuel lines are draining back..The cranking is only having to re-prime it..
    give em hell, the 2.2dti is a fine engine..
    Regular Member Braggy's Avatar
    Jun 2006
    St Helens
    I had this problem with a similar car unlike the vectra b where the problem was injector seals causing the fuel to drain back, the fault is recognised by vauxhall and a solution is posted on technical solutions, under the bonnet next to the battery is a fuse box, the route of the problem is weak electrical connections under this fuse box. the solution is to close the connects for a better fit using a pin or the propper and long winded way is to replace the affected connections one by one, to test the connections simply plug a male terminal in and pull it out again, if there is very little/no resistance then take the relivant action.
    hope this helps
    Braggy
    Jun 2006
    Plymouth
    Thumbs up thanks lads
    Thanks lads, very helpful. now i can take it back to the garage with an idea of whats wrong. dont want the garage to pam me off with some excuse.
    Once thats sorted Mackie ,its time for the MODS,, i know you have done 1 today....
    tell us more??
    Jun 2006
    Plymouth
    Default Thanks Micky
    Thanks for fitting the repeaters today Mick. Dont forget the tail lights mate. Only the one problem with this site, The more i see of modded cars the more i want one. Can see this costing me a bit of money, but well worth it and i dont have to justify it to the other half.
    Spoke to Pioneer (andy), and he will send you a pm mackie...All you want now is some 19" alloys...Speak to John (CDTI) i sure he has a set for sale at a fantastic price......
  1. Z28NEL Hard to Start
    By lee632 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2014, 07:28
  2. signum dti hard to start when warm
    By deano1 in forum Engine & Drivetrain
    Last Post: 17th September 2012, 07:30
  3. hard to start
    By bobbleheadbarney in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd May 2012, 13:29
  4. V6 CDTI sometimes hard to start
    By Celes in forum Engine & Drivetrain
    Last Post: 14th July 2010, 10:48
  5. hard to start
    By andrew m in forum Engine & Drivetrain
    Last Post: 21st October 2008, 20:30
