Results 1 to 10 of 27
Thread: Multiple Warning Lights!
    Jul 2009
    Scotland
    Default Multiple Warning Lights!
    All below relates to my 05 Vectra 1.9 CDTI SRI:-
    Help!
    I've just driven home from work. After a few minutes of driving the red battery warning light came on though the car continued to drive ok. After a mile or so (thankfully I was almost home) the yellow steering wheel warning light came on and it was was one hell of a struggle to turn the wheel and manouvere the car around a corner / park etc. When I got into my parking space and had killed the enigine I tried to restart the car to see which warning lights stayed on but now the car wont start and I'm getting the "spanner" (service?) warning light?! The car was serviced in July and has only done couple of thousand miles since then
    Any help / advice for this newbie would be greatly appreciated!
    Al
    Full Member spennny's Avatar
    Blantyre
    Could be the Alternator mate
    Just guessing , can you try and do the manual way to retrieve the codes, then someone could help
    looke here http://www.vectra-c.com/forum/showthread.php?t=81742
    Regular Member signum03's Avatar
    worthing
    sounds like battery has had it and no longer holding charge.
    Jul 2009
    Scotland
    Spenny,
    Many thanks for the assistance.
    Unfortunately the technique for obtaining the code doesn't seem to be working in my car (I get no flashing lights to count).
    Strangely my car started this time with no warning lights present?
    Also my power steering appears to be working again?
    I probably should of mentioned earlier but the red battery light came on yesterday when I was driving and the car continued to work fine throughout. Admittedly it was another short journey.
    Jul 2009
    Scotland
    Signum,
    Many thanks for your advice also.
    I've been reading through the forums and came across similar issues with regard to the alternator. Can anyone please advise which numbers I should be looking at with regard to the folowing recall issue that was posted in another thread:-
    Model - Plant - From - To
    Vectra C/Signum - Russelsheim 41080136 - 51000100
    Vectra C - Ellesmere Port 48066725 - 48110149"
    What do these numbers refer to?
    I looked at my VIN and it has 10 numbers and my engine number has only 7
    Regular Member VECTRA HEAD's Avatar
    Derry
    this has happened to me m8,it turned out to be a broken crankshaft pulley,all the warning lights came on,battery light 1st,then the electrics started to cut out eg. heater,power steering, headlights etc
    Jul 2009
    Scotland
    Many thanks for the response.
    Is there any other symptons that would indicate that this is the problem and if you don't mind me asking how much was it to fix?!
    Jul 2009
    Scotland
    Good morning all.
    I guess this is the last roll of the dice for me.
    With the problem I'm having with the car it looks like I'm going to have to go to the main stealer as it's across the road from me.
    Does anyone else have any info to add to this thread?
    Particularly with reference to:-
    Can anyone please advise which numbers I should be looking at with regard to the folowing alternator recall issue that was posted in another thread:-
    Jul 2009
    Scotland
    Good Afternoon All,
    I've managed to get down with my multimeter this afternoon.
    I'm getting 11.6V with the engine switched off and with the engine switched on it's dropping to 10.5V. My lights came on when I tried to add load and I couldn't get my vents to blow. At no point (with the engine switched on) did the voltage rise above 10.5V.Would you agree that this (along with the other information in this thread especially post 1) indicates my alternator's on the blink?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    To me it sounds like alternator
    Irmscher Insignia CDTI 130
  1. warning lights
    By ian 1234 in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 20:34
  2. warning lights
    Last Post: 15th April 2012, 13:49
  3. ABS and t/c warning lights
    By jossyboy in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2009, 17:36
  4. warning lights
    By jules in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 22:09
  5. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
