Results 1 to 10 of 11
Thread: my vectra c 1.9cdti 150
    Jan 2010
    sussex
    Exclamation my vectra c 1.9cdti 150
    can someone please help me i have a vectra 1.9cdti estate and the car with the spanner light came up on my car cause lack of power. i took it to a garage to get a fault code, but there were unable to get any codes. where i drove away from the garage that light has gone powe is back but still jerky at low revs but now i have the engine symbol on all the time. in the manual it says in engine/ exhaust emissions.
    does anyone have any ideas? i was thinking egr valve?
    please help as i use the car for work.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Prime suspect would be the EGR (I'll not mention swirls just yet), yours being the estate it will have a DPF which can cause these kind of symptoms - but EGR would be my first port of call to check.
    Jan 2010
    sussex
    Default vectra c 1.9cdti
    can anyone please tell me what a dpf is please. haveing problems with my vectras power at low revs.
    Sep 2009
    Swindon
    diesel particle filter. you really need to know what the fault code is, if the engine light is on then there will be a code.
    Have a look in the how to section there is some info on how to read fault codes for free, or see if someone local to you has op-cop or tech2 that can read the code.
    Frenchman
    Jan 2010
    sussex
    Default dpf
    where is the dpf located on extate vectra c? is it no the fule filter? just had this changed in the service. cheers guys
    Oct 2007
    west yorkhire
    The dpf is part of the exhaust system, it looks quite similar to a catalytic converter.
    Jan 2010
    sussex
    does anyone no what error code 1901 is on a vectra c sri cdti?
    Bristol
    Vehicle : CDTI 150
    P1901 is 'Particulate Filter Pressure Sensor' - this points to the DPF.
    There should also be a bit more txt; e.g. High/low pressure/voltage or figures not plausible or hose
    Jan 2010
    sussex
    have just had vauxhall on phone dpf sensor need replacing but also saying ecu faulty they quoted me £900 to replace the ecu.
    do you think the ecu fault could be down to dpf fault?
    Jul 2009
    N. Ireland
    Hi, dont pay Vx the £700 they quote for a new ecu. The same ecu can be got brand new for £395+vat. I'll post you a link when i find it.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. vectra c 56 1.9cdti sri help
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 20:38
  4. vectra 1.9cdti
    By VEC04MO in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2009, 19:20
  5. Vectra SRi 1.9CDTI 150
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2009, 19:18
