Results 1 to 10 of 14
Thread: How much to change Aux belt?
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default How much to change Aux belt?
    Hi all has any one got a stealer to change the aux belt for them if so how much is a good qoute. mines for a Signum 04 2.0 Dti
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Its a pretty simple DIY job, belt cost me £25 ish... but if you dont fancy having a go i'm guessing an hours labour which at VX here is around £65 plus the £25 ish for belt
    Nov 2007
    Leeds
    ive heard it is easy, i havent done anything like it before so is there a How to knocking about?
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    I will no boubt be corrected if I am wrong but I thought that the aux' belt was held in place by a spring loaded idler pully. To remove the belt place a spanner/socket on the idler nut and push against the spring to slacken the belt and remove, then slowly ease back the spring. Place new belt into position around the other pullies, push back idler, fit belt over idler and ease idler onto belt, job done.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would have thought the same too. On the 1.8 it is as simple as that.
    If you really can't do it yourself, DON'T go to the dealer and pay an hours labour for essentially less than 2 minutes work. Go to any garage and 'slip' them a fiver.
    I wonder if Halfords will fit it for you?
    Nov 2007
    Quote Originally Posted by carpet View Post
    yep that is right... but it took me a good 30 mins as space is limited but quite straight forward.
    Nov 2007
    Leeds
    i will certainly give these instruction some consideration. ill take some pics and ask for you knowledgable chaps to point in the right direction
    May 2008
    Tyneside
    Having been supplied with incorrect belts in the past it's worth noting the belt length is usualy printed on the outside. Also a good idea is to make a little diagram of belt route as it's not always obvious when refitting.
    Nov 2007
    Quote Originally Posted by tridley View Post
    yeah belt length depends if you do or do not have air con
    Nov 2007
    Leeds
    I think ill have a go at it myself this weekend....sounds simple enough!
    but for reference vx quoted £78 inc parts and labor + VAT
  1. Cam belt change
    By jacko52 in forum Diesel Engine related
    Last Post: 10th January 2011, 22:01
  2. Cam belt change, do I get it done?
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2010, 13:27
  3. Cam Belt Change
    By darrenmac in forum Engine & Drivetrain
    Last Post: 17th June 2008, 20:59
  4. Cam belt change now or later
    By mr.4dil in forum Engine & Drivetrain
    Last Post: 20th February 2008, 22:57
  5. 03 1.8 sxi cam belt change
    By mickeyc in forum Engine & Drivetrain
    Last Post: 10th October 2007, 08:18
