Results 1 to 3 of 3
Thread: Roof Bars ~ how to remove?
    Jan 2010
    Reading
    Default Roof Bars ~ how to remove?
    Do you know if I can remove my factory fitted roof rails from my T reg Vectra and put them on my 2007 Vectra both are estate cars.
    If they are the same do you know how to remove them? I have no idea where to start, there are no screws and no movement in the bars so you can't push them in a any direction.
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    The roof rails aren't compatible between the two. However it is possible to retro fit roof rails on to the estate, basically you have to drop the headlining onto the headrests, undo and drop the curtain airbags, remove the exisiting roof rail trim, drill out a couple of pop rivets each side then bolt on the new rails and trim down the windscreen trim to fit. Took me about 4 hours taking it steady. The rails crop up every so often on Ebay or they are roughly £100 a side from the dealer
    Jan 2010
    Reading
    Thumbs up Thanks
    Thanks tramman
    I think i'll leave it then, sounds like a very hard job, and pointless as they don't fix the newer car.
    Thanks for the reply, I was looking for that info all over the net.
  1. fiiting roof bars on the roof rails of a vec estate 2004
    By tinus71 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 19:50
  2. Roof Bars and box
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 15:19
  3. Roof Bars / Roof boxes for 2006 Signum.....
    By signum_1.9 in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2009, 20:28
