Results 1 to 10 of 23
Thread: 1.9 cdti thermostat
    doncaster
    Default 1.9 cdti thermostat
    can any one shed light on this my temp gauge never moves i meen stays at the bottom seen other post about thermostat but car seems not very good on diesel has any body else got better mpg by changing thermostat
    Full Member Big Sig's Avatar
    If its running cold then thats the first place to look. get it changed
    doncaster
    thanks for reply but do you think the bad mpg is to do with it running cold thanks
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Usual 1.9 fault. Get thermostat changed.
    Nov 2007
    weymouth, dorset
    That will be down to it running cold all the time.
    doncaster
    cheers will get it sorted then thanks for info
    Warrington
    I have the same problem at the minute with my temp
    gauge not moving, I have had the temp sensor changed but car still feels sluggish and us drinking the fuel like no tomorrow. The garage said they were no error codes that they could find and weren't too sure
    what the problem could be so I don't know to do? I have read somewhere that the erv valves or something might need cleaning in the manifold?
    Nov 2007
    weymouth, dorset
    I asume you mean EGR valve? Will have nothing to do with the running temp of the engine.
    doncaster
    mine runs sweet as a nut just not great on fuel
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Where do you buy 1.9 thermostats????
  1. thermostat 1.9 cdti 120 and 150 is it the same?
    By grabos in forum Engine & Drivetrain
    Last Post: 7th January 2013, 17:35
  2. 1.9 CDTI 8v THERMOSTAT
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 7th September 2012, 19:17
  3. 1.9 cdti 120 Thermostat Mod
    By no1vic in forum Engine & Drivetrain
    Last Post: 20th February 2011, 21:43
  4. 1.9 CDTI thermostat
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 27th January 2011, 07:07
1.9cdti thermostat never moves
