Thread: Passenger door wont open from outside
    Jan 2010
    Lisburn
    Default Passenger door wont open from outside
    As above, the door will not open from the outside, but can be opened from the inside, when pulling on the door from the outside, it feels a little easyer to pull that the other doors.
    Could something need tightened, or has something broken?
    Jan 2010
    Lisburn
    Took the door handle off completely from the outside, the lever is still attached to the handle when you push it in, you can feel a little resistance when pulling, but not as much as a working handle, I supose this hasnt happened to anyone before that knows a quick fix or what sort off bill im looking at?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    56 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Haven't a clue buddy sorry so here's a free
    Irmscher Insignia CDTI 130
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    hi mate whip the door card off and look from inside at the lock its self make sure the rod that comes down from handle is sat in its plastic clip properly check that the rod isnt been obstruted by anything.this was a big problem when i worked for fiat on the stilos which have the same set up hth
    Jan 2010
    Lisburn
    Thanks mate, I half took the door card off today also, noticed that it was covered with a plastic sheet, can that be detached if I need to put the metal rod back if it has came off the clip?
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    sorry for delay mate being on bathtime duties the plastic sheet is called a membrane it stops any water that gets past the window seals entering the car what i normally do is cut a flap in it where you need access do the work then stick it on both sides with gaffer tape which is waterproof.if the rod has come out push the rod back into plastic clip then rotate the clip,
    Jan 2010
    Lisburn
    No worries, thanks alot!! - Will give that a go the next dry available day, - the mechinism works from the other side, so this seems to be the solution im after cheers!!
    Jan 2010
    Melbourne
    Default Child lock engaged ?
    Easiest thing first.
    Make sure the child lock is not engaged.
  1. Passenger Door Locked Wont Open!
    By Street Hawk in forum Troubleshooting
    Last Post: 11th December 2015, 10:22
  2. Passenger door wont open
    By peelmeister in forum Troubleshooting
    Last Post: 28th February 2013, 12:32
  3. Help.... can't get my passenger door open......
    By houston in forum Bodywork & Interior
    Last Post: 17th October 2012, 14:56
  4. door wont open
    Last Post: 10th March 2010, 20:31
  5. door wont open
    By neverlandandy in forum Bodywork & Interior
    Last Post: 25th January 2009, 13:29
vectra c passenger door wont open
vectra passenger door wont open
vectra door opens from inside but not outside
vauxhall insignia side door wont open from outsidevauxhall insignia doors wont openvectra door wont open door handle will not open the passenger door on my 07 vectra srivectra c passenger door wont open from outsidevauxhall vectra passenger door not opening from outsidevectra c 1.9 cdti passenger door not opening from outsidesignum door not opening from outsidepassenger door wont open from outside vauxhall corsa zafira b passenger door wont open from outsidezafira b front door wont open from outsidevauxhall zafira handle wont openvauxhall zafira door wont openhow to unlock a corsa door from passenger.sidecannot open vauxhall corsa door from insidevectra c door wont open from outsidewhat to do when a vetrac door wont open from the out sidepassenger vectra door wont open from outsidevectra c cant open door from inaidevauxhall vectra door not opening from outsidevectra c rear door wont openopel corsa door wont open from outside
