Results 1 to 10 of 13
Thread: strange warning light vauxhall dont no what it is
    Apr 2009
    stockton-on-tees
    Default strange warning light vauxhall dont no what it is
    does any 1 no what this is? my rear pads are realy low could it be that my diagnostic comp doesnt seem to pick it up either
    East Midlands
    Brake pad wear indicator.
    Apr 2009
    stockton-on-tees
    sound i thought thats wot it wud be so wen i put my new pads on tomorrow will the light automatically go or will it need clearing with my comp?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    As far as im aware the indicator is only linked to the front drivers side brake pads.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Regular Member signum03's Avatar
    worthing
    vauxhall should know this????
    East Midlands
    When you renew your pads,buy a sensor from stealers and refit light will dissapear ,no need for tech 2.
    Oct 2009
    rhyl
    its a con more than likley you have to buy the wire which brakes when you change pads ,only about £15 my dad has just joined the wires and it goes out but obviously you know when your pads are quite low i personally would buy it but on my vec the previous owner just left it now mines on all the time
    Full Member Penfold101's Avatar
    Ok, to clarify:
    The warnign light is for the front brake pads. If sensor works by being worn down when the pads are worn to break the cicuit, so when replacing the pads you need a new sensor, or as mentioned above you simply strip and attach the two wires together. This is what I did, as I refused to waste £10 on a sensor that I can do the job of by simply USING MY EYES...
    The rear pads do not have a sensor on them.
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    its the front passanger side thats the only ware indicator on the vectra
    Full Member Big Sig's Avatar
    Now, where's the manual, oh and a dictionary.
  1. Strange Warning Loght Combination....
    By Brummie in forum Engine & Drivetrain
    Last Post: 14th February 2013, 09:29
  2. strange warning light
    By chrissri82 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2011, 01:25
  3. Fuji GP Warning spoiler, dont look if you dont want to know!
    By rushy in forum Motorsport / Formula 1 etc. chat
    Last Post: 12th October 2008, 13:23
  4. 2.2 2003 Vectra Strange Warning Light Problem?
    By sophos9 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 13:16
