Likes Likes:  2
Results 1 to 10 of 13
Thread: vectra c radiator replacement ?
    Jan 2010
    croston lancashire
    Default vectra c radiator replacement ?
    hi there is there a how to on changing radiator on my vectra c . thers is an air con rad in front first. what do i do to get the rad out . can i leave the air con rad in . any help would be great
    Jan 2010
    croston lancashire
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    through the front. Take bumper off and move the a/c rad to the side then take it out the front. You could get a a/c copany to empty it then refil when its done
    Sep 2009
    Swindon
    When I did mine I took it out from underneath, I used some cable ties to hold the air-con unit in place. There are a few well awkward screws to get at, and a good set of hose clamp pliers will come in handy.
    Get someone to give you a hand when your ready to actually take it out, as it's a bit fidly otherwise.
    Frenchman
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Sparks
    as frenchman says take it out downhill it saves having to have aircon regassed. (saves you £40 or £50)
    Jan 2010
    croston lancashire
    ok well doing it in the morning will have a look hope its not raining again . so can it not pull towards me and just disconnect it from the front one then slide it up ?
    May 2016
    UK
    Vehicle : Vextra
    Trim : SRI 2.0 TURBO
    Engine : 2.0 turbo
    How did you get on?
    5 Post(s)
    Quote Originally Posted by jaygsi View Post
    How did you get on?
    Sparks is unlikely to reply, as he was last seen here 17th February 2010
  9. Likes Dog_Book liked this post
  10. #9
    Midlands - Head Honcho Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    92 Post(s)
    Trim : VXR
    Engine : Z28NET
    Year : 07
    Clever clogs
    Eibachs B8's, Hansen drl/fogs, fully loaded factory options
  11. Likes Big Dave liked this post
  12. #10
    5 Post(s)
    Quote Originally Posted by Dog_Book View Post
    Clever clogs
    All it took was a quick look as his profile for the info.
  1. Vectra C Radiator HELP!
    By jbmf90 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2013, 14:48
  2. Intercooler radiator removal without water radiator
    By Whosane in forum Troubleshooting
    Last Post: 5th December 2012, 15:48
  3. Vectra 1.8 (54) Radiator
    By coolcatkelso in forum Engine & Drivetrain
    Last Post: 15th August 2012, 01:44
  4. radiator replacement
    By sparks in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2010, 20:02
  5. vectra b radiator fan
    By larson in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2009, 20:55
vectra c radiator removal
vauxhall vectra radiator removal
vectra c radiator change
diagram of radiator removal on vauxhall vectra 2003
replacing radiator in vectra
how you change radiater for vauxual vectra
radiator removal vectra
remove radiator vectra c
how to remove a radiator for a vectra c
changing a radiator on a vectra c
vectra c 2007 1.8 air conditioning radiatoropel vectra c engine radiator removalvectra radiator removal2007 vectra radiator change2007 vaxhall vectra radiator remove allhow to remove signum radiator how to remove vectra c air con radiatorradiator removal 2004 vauxhall vectravectra c condenser replacementvauxhall sigum radiator replacement can a vectra c radiator be removed without removing front bumperremove radiator vectra c with air conditioningchanging a radiator vectra c automatic remove vauxhall vectra c radiatorvectra c 1.8 radiator removal
