Thread: vectra c rear wheel knocking
    Jan 2010
    croston lancashire
    Default vectra c rear wheel knocking
    hi there been having knocking problems at rear and have found out when you put you hand at the top middle of wheel and start pulling it moves but with a knocking when the wheel is off there is no play in the hub or brakes . i suspect its up somwhere i can hear it. what you think this is really need help on this . only knocks over rough ground pot holes on flat and motorway its smooth
    hull
    upper trailing arm pal, replace both sides at same time though.
    can be bought off ebay for about £30 the pair. fitting diy or 2hrs labour.
    Edinburgh
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=160352026771
    There is a How-2 on changing them as well. I'm looking at doing them soon too.
    Jan 2010
    croston lancashire
    yea that sounds about right is there ahow to on it ?
    Edinburgh
    Jan 2010
    croston lancashire
    got it thanks for that just my dam rattle after this i put foot on brake it stops not sure which ones are doing it had a look at rear today cant feel any play never looked at front i give up cause it was too wet .
  1. 2008 Vectra rear knocking
    By maxx470 in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2012, 19:30
  2. Vectra C, 2002, Rear Suspension knocking/creeking noise
    By richardkay007 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 19:05
  3. vectra 1.8 duelfuel 2003 knocking at rear
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 00:39
  4. Loud knocking from Left Rear Wheel
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 18:46
  5. rear wheel knocking
    By Flyingdutchman in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2008, 22:40
vectra knocking from rear
vectra c rear wheel knocking noise
knocking in rearwheel vectra c
knocking rear wheel vectra c
vectra c powerful knockig in holes
knocking from rear vectra c
knocking vectra c likely
vectra c rear suspension knocking
2006 vectra makijg knocking noiserear left side
