Thread: Which Oil Vectra 2.0 DTi
    Regular Member speedcat445's Avatar
    Jan 2010
    Wigan
    Default Which Oil Vectra 2.0 DTi
    Which oil required for 2003 2ltr DTi, is it fully or semi synthetic 10-40 or 5-30, thanks in advance
    West
    Either will be fine although if it's high mileage the 10/40 will be better imo & it's what i used in my old dti
    Jan 2010
    Wigan
    130k with full service history but will be doing my own servicing, as I always have done.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    5-30 mate
    EVERYWHERE
    10w-40 with those miles.
    5w-30 is great if you want to save a bit of fuel, but 10w-40 will be better at keeping the oil where it's supposed to be...in your engine as opposed to out of the exhaust pipe, since it is less likely to weep passed turbo oil seals and valve guides.
    10w is just as good as 5w down to -20C and '40' is better than '30' at high engine temps (towing, hard acceleration etc). And I would assume that you are changing it annually, in which case don't waste your money on the long life fully-synth stuff. Semi-synth will do just fine.
    Professional Trader oilman's Avatar
    Nov 2005
    Cornwall
    6 Post(s)
    Vehicle : Posche
    Trim : 928 S4
    Engine : 5.0
    Year : 1989
    Quote Originally Posted by speedcat445 View Post
    If you look up your model here http://www.opieoils.co.uk/c-861-car-engine-oils.aspx You should find a selection of suitable oils.
    Guy
    oilmans website : www.opieoils.co.uk/
    e-mail : oilman@opieoils.co.uk
    tel : 01209 215164
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
vauxhall vectra 2.0 dti 2004 engine oil
https:www.vectra-c.comforumshowthread.php100684-Which-Oil-Vectra-2-0-DTi
engine oil for vectra c 2.0 dti
what oil goes in a vectra dti
is 5w 30 semi synthetic oil ok for my vectra c
what oil is needed for a 2004 vectra 2 litre ctdi
vectra c 2.0 dti oil
opel vectra c 2.0 dti oil
vectra c 2.0 dti recommend oil type
vectra c 2.0 dti engine oil
what oil for zafira 2.0dti
opel vectra c 2.0 l 2004 oil
signum dti oil
engine oil for zafira 2.0 dti what oil to pit in a dti 2 litre vectrathe right oil for Zafira dti 2004oil for vectra 2 ltr tdimotor oil for opel zafira 2.0 dtivauxhall zafira a dti oilvauxhall vectra 2.0 dti 2004 oil type motor oil for 2004 vauxhall vectra 2.0 dtimotor oil for astra g 2.0dtivauxhall vectra 2l diesal oilvauxhall astra G 2.0 dti engine oilvectra b 2.0 dti recommended oil
