Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: snowfoam question
    Aug 2009
    north wales
    Default snowfoam question
    hi there everyone, want to start using snow foam on my car, been looking on the clean your car website at the lance's for pressure washers. at the min i only have a little halfords own one will this be powerfull enough? also what lance adaptor will i need to make it work?
    also seen this on clean your car, will the water pressure from an outside tap and hose pipe be enough pressure? http://www.cleanyourcar.co.uk/washin.../prod_329.html
    Mileage : 000
    I use an ordinary hosepipe on an outside tap, with a Gulmour foam gun. It does the trick for me. But admitedly it is not as "foamy" as when a "say" Karcher presure washer is used. It still softens the dirt and it comes off easily enough though, especcialy if there is a good coating of wax on the car.
    Aug 2009
    north wales
    thanks for reply mate, u got anypics of ure car with the snowfoam coating? still tryin work out if they do an adaptor for the pressure washer ive got!!!
    Glasgow
    I would recommend auto-brite direct there guys are often on here and they give some sound advice and sort us all out.
    To answer the question, snowfoam wont work to full effect without buying a proper foam lance that attaches onto your original lance. Here is a link with a few videos of what you will get if you buy the foam lance http://shop.autobritedirect.co.uk/au...ions-305-p.asp
    If you give them a buzz they sould be able to tell you what connection does your pressure washer
    Aug 2009
    north wales
    cheers mate help apreciated!!!!
    Aug 2009
    north wales
    have just emailed autobrite so see what they say!!!!!
    Mileage : 000
    Quote Originally Posted by lloyd_456 View Post
    If you asked me about two hours ago I could have taken one or two for you.I have just given my motor a good wash. I don,t have any ols snowfoam photos belive it or not.
    Aug 2009
    north wales
    typical mate always too late,lol
    Blantyre
    I will be doing mine in about an hour if you want some pics of before and after
    Aug 2009
    north wales
    Quote Originally Posted by spennny View Post
    that would be great if u dont mind mate?
    what snowfoam set up you got?
  1. snowfoam
    By Al 22 dti in forum Detailing and Car Care Discussion
    Last Post: 19th August 2011, 10:42
  2. First snowfoam!
    By GSiFan in forum Detailing and Car Care Discussion
    Last Post: 6th February 2011, 17:31
  3. best place to buy snowfoam lance and snowfoam
    By paul_sri150 in forum Detailing and Car Care Discussion
    Last Post: 31st January 2011, 23:04
  4. Tried to have my snowfoam away
    By shan in forum General Chat
    Last Post: 17th April 2008, 23:08
