Thread: Interior oddments tray mat
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Interior oddments tray mat
    Not a big problem really, but, in the oddments tray underneath the stereo there is a rubber mat to stop things moving about.
    On my car this mat is very loose and just slides out.
    Is this correct? How is it supposed to attach, mine doesn't.
    I will probably use double sided tape to stick it down but was just wondering...
    Thanks, Mark
    Regular Member Ian's Avatar
    York
    Its loose, but shouldnt slide everywhere due to the surface of the matt "sticking" to the bottom of the hole. Maybe yours in worn out Mark? You could get a new one or like you say, just use double sided sticky tape.
    [Ex]Admin Duncan's Avatar
    As above, it's not stuck in but it shouldn't slide around. Maybe the surface (of the mat) has become 'polished'. Give it a bit of a going over with some very fine emery type paper and that should roughen it enough to make it stick again.
    Mileage : 000
    Or clean it with some meths, that should get any grease of if that is making it slip off.
    Regular Member ope126's Avatar
    May 2006
    Brisbane, AUSTRALIA
    Just checked mine out...
    It has a hole in the dashboard area and the mat has a guide to fit in that hole. If it is position correctly, it should not move around.
    Melbourne, Australia
    Quote Originally Posted by ope126
    Yep, mine too. It took me a while to realise what the hole in the dash was for...
    Jun 2006
    North West
    Yes Ive just seen that hole. But the mat doesn't fit that nicely in it.
    The car is 10 months old and the mat doesn't look worn.
    I think its me being too picky.
    I'l clean it first then sticky tape.
    Cheers guys
  1. Interior tray removal
    By MrSignum89 in forum Bodywork & Interior
    Last Post: 17th June 2011, 12:24
  2. Oil on under tray
    Last Post: 17th October 2010, 17:27
  3. under tray
    By temprahater in forum Engine & Drivetrain
    Last Post: 11th October 2010, 17:43
  4. Tray Up
    By AJA in forum Comedy & Humour
    Last Post: 22nd February 2007, 09:33
