Results 1 to 10 of 15
Thread: Does the 1.8 have an EGR valve?
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Default Does the 1.8 have an EGR valve?
    As the title says, does the 1.8 engine have an EGR valve & where is it situated?
    I have done a search for it in the How2 section & here, but it just seems to be 1.9 oil burners that are mentioned.
    Don't want to appear thick, just want to use the fantastic experience of fellow members.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I assume you mean Z18XE, ie non VVT?
    If so, early ones did and it is located in the area above where the gearbox joins the engine. After about 04 it was deleted and a blanking plate fitted.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Yes, it's the Z18XE in a July 2004 registered LS. I had a look a few days ago, but couldn't see anything obvious. Oh well, i will investigate further.
    May 2008
    Derbyshire (south)
    Hmm, maybe i should check mine out here, then. Mine is a 2003 1.8 so,,,
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If I get time later, I will take a picture of where it is located
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Here is the promised picture. I had lifted the battery cover up and looked into the area under the engine cover and above the gearbox joint to engine. The oil level dipstick tube support stay connects to the bottom blanking plate bolt.
    May 2008
    Derbyshire (south)
    ooh that looks easy to get at??
    Tyvm for the pic, I will have a peek for mine & see what its like, I have plenty of carb cleaner.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    the pictures below show the EGR valve when fitted.
    I blanked mine off last october, got a blankin plate from ebay.
    mines a 53 plate 1.8LS
    May 2008
    Derbyshire (south)
    How did you get on Carl with blanking it off?
    no problems at all, it stores a fault (no EGR valve) but doesnt show any warning lights. and runs great.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
vectra c 1.8 egr valve location
egr valve vectra c 1.8
vauxhall vectra 1.8 egr valve location
https:www.vectra-c.comforumshowthread.php100669-Does-the-1-8-have-an-EGR-valve
vauxhall vectra egr valve location
egr for 1.8 vectra
vauxhall insignia 1.8 petrol egr
egr valve vauxhall vectra 1.8
egr valve vectra 1.8 vvt
where is egr valve on zafira a 1.8egr valve for opel astra z18xe 2006 1.8does a 1.8 52 vectra c have an egrvauxhall vectra 1.8 sri egr valvevauxhall zafira 1.8 petrol egr valve locationegr valve vectra 1.8 petrolvectra egr locationegr location vectralocation of egr valve on a zafira 1.8 club 20032005 vauxhall vectra c 1.8 petrol egr valvevectra c 1.8vvt egrzafira b 1.8 egr valvewhere is the egr valve on vectra c 1.8Vauxhall Vectra 2003 1.8 petrol where is the EGR valve on the enginevauxhall astra egr valve location
