Results 1 to 10 of 22
Thread: Help! Cleaned EGR now no power
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default Help! Cleaned EGR now no power
    Please help me someone! I was suffering from loss of low down power (below 2000rpm) and had to P0400 fault code so decided to take the EGR off and clean it today.
    It was coked in soot which I cleaned off with the aid of some WD40. The pin for the solenoid was stuck about 3-4mm out.
    I tried the drill method and tried to punch out the solenoid but it didn't budge. The pin did budge and came out another 2-3 mm. I pushed it back in and it stayed as it was before, not sitting flush but about 3-4mm out.
    Put it all back together and took the car for a spin, now it's really struggling throughout the rev range. It's very lumpy below 2000 and now I can't feel the turbo kick in when it does finally hit 2000. When idling I can hear the turbo spinning up at 2000 revs.
    One thing I noticed was that if I gently press the throttle the revs will go up smoothly. If I try and floor it though, the engine struggles and just sounds like it going "rum-rum-rum-rum-rum" even though the throttle is steady.
    What the hell have I done???
    Jul 2009
    Wiltshire, UK
    Forgot to say, there's no warning lights on.
    Jan 2010
    Newcastle upon Tyne
    check all hoses relating to the turbo, make sure no holes are steadily getting bigger. Ive had to change both mine with simlar running problems. rst time I went to trade club, flabbergasted at the price, I told him I wanted a piece of hose not a new turbo. Second time ased my neighbou to gt mea hose from one of the big diesel engines on the trains since he is a fitter for them. the pipe is approx 3 inches, impossible round my way to get a hose from accessory shops but Ive since heard normallya lorry accessory place stocks these hoses. dont think its the egr valve, freeing it off should have made it run better not worse. From past history Ive found when this happens Ive traced three holes in hoses and the air intake hose under the top cover was blown off, my own fault that one but we ll not dig to far
    Jan 2010
    Newcastle upon Tyne
    Oh ast ime when the hose blew of the air intake I also had no warning lights
    Jul 2009
    Wiltshire, UK
    Sorry to sound thick, but where are these hoses?
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Id say that EGR valve is knackered, if the soleoid plunger is still siezed it wont open and shut the EGR valve and cause flat spots etc..
    Jul 2009
    Wiltshire, UK
    That's what I was thinking, the valve may be stuck in a different position to what it was before causing juddering under acceleration?
    One other thing that happened today, my undertray was dragging along the road as I turned into my street. I whacked it back on with a firm hand and tightened this screws, could I have dislodged anything from the underside of the engine?
    Nov 2007
    weymouth, dorset
    Wouldnt have thought so, You should be able to get the plunger out of the solenoid, after drilling the hole it should tap out then you can clean the plunger and it should be ok. I have had a few that are stuck fast butdo come out eventually. Failing that new one!!
    Apr 2009
    stockton-on-tees
    have u reconnected cable to the egr ?
    Jul 2009
    Wiltshire, UK
    Yes, first thing I checked!
    I'm convincing myself the EGR is fubar'd. It would be highly coincidental if some other part has failed at the same time I cleaned the EGR.
  1. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  2. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  3. Replies: 11
    Last Post: 7th January 2010, 17:50
  4. EGR Cleaned.... More Power?
    By redraptor_141 in forum Engine & Drivetrain
    Last Post: 24th March 2009, 20:26
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
