Results 1 to 10 of 27
Thread: My EGR Fail ( part numbers needed )
    Regular Member Lump's Avatar
    coventry
    Default My EGR Fail ( part numbers needed )
    So day started off going to get the new motor for the broken wipers.. got that done and fitted in about an hour. not sure about the scuttle panels fit afterwards though ah well.
    Then i thought what a great idea ill do the EGR up up the how to and start to pull bits off the car. the pics are nothing like the 120BHP engine. but ill give it a go after all, every one said how easy it is. SO loose both metal gaskits and the gasskit on the hose at the bottom. But the hole of the EGR was full of soot and it did need a good clean. same i wont know if it works
    So guys can i have part numbers for them. two for the large hole and the two smaller to bolt on and the one for the bottom of the hose.
    coventry
    no one ?
    coventry
    50 views, shame this place used to be a helpful one
    milton keynes
    hi mate , is it still suffering the same after you have cleaned it?
    Feb 2007
    North west
    Hi, you dont have to change the metal gaskets unless they are damaged. I have cleaned mine about 3 times and re-used them with no leaks. Carb cleaner is the best bet but make sure you dry it completely before re-fitting to avoid EM lights. Well worth cleaning the boost sensor if your EGR is like that too.
    No pressure washes or special waxes needed for this job !
    If you are going to change the washers do a search for the Fiat gasket kits - they do restrictive replacements that keep the soot build up much lower in the valve.
    coventry
    I've lost all three of the gaskit down into the engine
    Sep 2009
    Swindon
    Quote Originally Posted by Lump View Post
    Maybe the people who viewed the thread don't know the answer so that's why you didn't get a response. Why can't you just go to your vx dealer and ask for the gaskets you need? That's what I did when I did mine, they will have a blown up diagram so you can see which ones you need.
    They are about a £1 each. Not rocket science is it?
    Frenchman
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    That doesn't sound good.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sorry mate ive had a quick look at EPC but its messing around on me and i cant see any pic's
    Irmscher Insignia CDTI 130
    coventry
    Quote Originally Posted by frenchman View Post
    Frenchman
    you see the header, Troubleshooting ? this is where people post up asking for help. bit of a give away really. and its not rocket science is it ?
  1. Are these the part numbers?
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2011, 19:08
  2. GM part numbers needed please.
    By thefibreguy in forum Handling & Braking
    Last Post: 5th July 2010, 09:30
