Results 1 to 10 of 13
Thread: White smoke strong
    Glasgow Scotland
    Default White smoke strong
    As above guys,car revs up slowly and lumpy.Just managed to get it home after starting this morn no probs.Went to the shops no probs.Started it back up white smoke strong smell no power.Need a soloution boys please,19CDTI 150.54 PLATE.
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    If it's thick white smoke coming out of the pipe and if you rev it up and it gets thicker could be you turbo blown ££££.......
    Glasgow Scotland
    Quote Originally Posted by big nath View Post
    No big bangs nothing.It was going fine when i stoped at the shops.
    Jan 2008
    Irthlingborough
    Have you looked at all the pipes under the bonet and pipes coming of the turbo and the intercooler.
    Oct 2009
    Bucharest
    I had this problem once and it proved to be water in the diesel, during dpf regeneration i've seen a big cloud of white smoke.
    Jan 2010
    Newcastle upon Tyne
    White smoke does generally point to a water problem, but a hole in one of the turbo hoses can also causes this. if its running fine, generally it wont run properly if a hose has a hole in due to lack of pressure regen pressure into the cyclinder head I think I would put it down to cyclinder head gasket, or cracked cyclinder head. Get it pressure tested, think worst first, check least probem areas first then it can only get better from there on. I hate my vectra today so the worst has happened. A double Whammy for me, so dont worry yet
    Glasgow Scotland
    Quote Originally Posted by daveywhite View Post
    Cant see any holes in hoses.Have a box on cr1 module.Could that be the problem.Black soot inside the exhaust thick dry soot.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    number 3 injector loom give that a wiggle ..then check if the egr isnt jammed open .....and check if you still have coolant lol ...
    Glasgow Scotland
    Quote Originally Posted by benny View Post
    [Plenty of water in the expansion bottle and pressurising correctly.Ok guys 3rd injector how to please?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Although it sounds like water I doubt there'd be a strong smell associated with it if it was!!
  1. White smoke
    By Mark fisher in forum Troubleshooting
    Last Post: 27th December 2012, 10:42
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  4. White smoke!
    By stickygreen in forum Engine & Drivetrain
    Last Post: 1st February 2012, 19:02
  5. White Smoke???
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 4th February 2011, 17:37
