Results 1 to 10 of 11
Thread: spanner ligh
    Regular Member mickg's Avatar
    High Wycombe
    confused spanner ligh
    got a spanner light when it's cold and dumpy... but after 2 minutes when enginee is warm it's disapear and never show again. Basicly it happens in the morning... well just morning... is it something I should worry about? Can it be to much water in that tank or whatever it is near fuel filter?? to much water? hmm...
    Please help.
    May 2006
    scotland
    I would worry about it but not to the extent of losing sleep. Should not do that. Maybe would be an idea to get it read on a fault code reader to see if any fault codes are stored. Then try disconnecting battery for an hour to see if it resets anything, it may just dissapear.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Might be a glowplug fault ?
    Irmscher Insignia CDTI 130
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    i had this and it was 1 of my glowplugs but i changed all 4,, had spanner light on from cold start but went out after 10-20 seconds, but now ive replaced them its all fine, another member on here had same prob he changed his glowplugs but still no joy turned out to be control moduel for glowplugs . i would try plugs first tho
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    Quote Originally Posted by bigmac View Post
    i had the same problem, 4 new glowplugs (and a lot of other shed as two of them snapped when changing them) and the problem was solved.
    High Wycombe
    thanks guys. are those glow plugs expensive?
    Jan 2008
    london
    iirc they should be around £10 per glowplug.
    High Wycombe
    thats allright then 10 quid not bad. I was ready to pay 30quid for each. uff
    Worcs/Staffs/Westmids (ish)
    Get it sorted asap, I don't agree with the "don't worry" suggestions on this occasion (sorry guys), because about one of the first thing I thought was oil pressure.....
    I don't want to panic you, but its one of those things that changes with temperature and i've heard of similar symptoms with dodgy oil pumps.
    It could and most probably is nothing serious, but I personally wouldn't risk it.
    Oct 2009
    coventry
    Hi had the same promblem with my 53'regd dti vauxhall dealer did a tech test said it was the ecu/fuel pump changed under a used car warranty i had with the car (£2500 total) after 2 weeks light was back on,they then changed the instrument bincale just before christmas so far no light,steve
  1. car with spanner
    By swvectra in forum Engine & Drivetrain
    Last Post: 10th July 2011, 10:00
  2. Oil can/spanner 1.000 .what is this mean?
    By Dobs in forum Engine & Drivetrain
    Last Post: 9th April 2011, 20:26
  3. car with a spanner through it?
    By mtcbrown10 in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 20:23
  4. car with spanner through it
    By wanna veccy in forum Engine & Drivetrain
    Last Post: 21st May 2008, 21:57
  5. car with spanner
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2007, 09:15
