Thread: bouncy ball in door
    Regular Member Elite 1's Avatar
    May 2006
    Denton, Manchester
    Question bouncy ball in door
    another problem iv had for a while now but while im in a sort it mood might as well ask! is that if you send up or down my ps electric window, about half way you can hear a noise like a bouncy ball bouncing!!! any ideas???
    also while im at it my gearbox crunches sometimes when i select reverse, i know it says d press the clutch for three secs before selecting reverse in the manual but it still does it! the only way i have found around it is to select another gear first then try reverse
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Didnt u see the addendum to the owners manual?
    Field Remedy BS101 - Says if crunching in reverse, select forward gear first...
    that way we can get out of another warranty job
    May 2006
    Denton, Manchester
    Thats true
    Chester
    did you ever find a fix for the bouncing ball sound? I hav a signum an also hear a sound which is as if somethings wobbling around somewhere.
    May 2006
    Denton, Manchester
    Took it to vauxhall in the end and they ended up fitting a new window lift unit! under warranty
  1. Bouncy bouncy
    By Nicolas in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2012, 09:47
  2. Bouncy, bouncy, bouncy.
    By kenbo in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2012, 16:10
  3. bouncy car
    By jools in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2007, 10:00
  4. Bouncy Bouncy
    By Stringlabel in forum Handling & Braking
    Last Post: 1st February 2007, 12:33
