Results 1 to 3 of 3
Thread: warranty
    Regular Member toughmat's Avatar
    Home Rhondda , Work in Cwmbran
    Default warranty
    Just bought myself a cdti 150 bhp and im loving at the moment, but im in need of some warranty!!
    Question is who have you got warranty with and how much did u pay ect, did/does it cover the egr valve,dmf and so on and so fourth.How much did you pay if you dont mind me asking ???
    would this cover the egr valve and dmf
    For details of cover see Policy Document
    The items under the following list are covered. Any item not specifically mentioned is not covered.
    ENGINE
    Cylinder head
    Cylinder head gasket
    Valves (excluding decarbonisation, burnt or pitted valves and valve seats)
    Valve springs
    Valve guides
    Camshaft and bearings
    Cam followers
    Hydraulic lifters
    Push rods and rocker gear
    Timing gears
    Chains
    Belts and tensioners
    Pistons
    Piston rings
    Cylinder liners and linear seals
    Connecting rods and bearings
    Gudgeon pins
    Crankshaft and bearings
    Oil pump and oil pump drive
    Distributor drive gear
    Distributor drive
    Flywheel and ring gear
    Flex plate/auto drive plate
    Inlet and exhaust manifolds
    TURBOCHARGER
    Internal failure of factory fitted turbocharger and wastegate.
    GEAR BOX: MANUAL AND AUTOMATIC
    Gears
    Shafts
    Synchromesh hubs rings and selector shafts and forks
    Extension shaft
    Torque convertor
    Automatic transmission clutches and brake bands
    Oil pump
    Bearings and bushes
    Valves and valve block
    Governor and servo.
    TRANSMISSION
    Crown wheel and pinion
    Differential gears and bearings
    Bushes
    Half shaft and half shaft bearings
    Driveshafts
    Bearings and constant velocity joints
    Propshaft universal joints and centre bearing hubs and wheel bearings.
    Only the components originally fitted as standard by the manufacturer are covered unless agreed in writing by us.
    Phone them and ask for a confirmation in writing of all parts covered :
    "All original engine components as supplied and fitted to a Vectra C SRi 1.9 CDTI 150"
    Warranty Wise paid for a EGR valve pipe on my previous Mondeo Mk3 TDCI
    It cost them £3.85 for the pipe and £385 in labour!
  1. Do I get a warranty??
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 13:00
  2. Warranty Direct or AA Warranty
    Last Post: 20th March 2010, 12:31
  3. Warranty
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 22:04
  4. warranty
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 21:13
  5. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
