Results 1 to 3 of 3
Thread: Swirl flap linkage fallen off but managed to bodge it! (I hope!)
    Regular Member jrwilshire2003's Avatar
    Bridgend
    Default Swirl flap linkage fallen off but managed to bodge it! (I hope!)
    Hi all,
    I know this has been discussed many time but just wanna confirm that if you get the linkage bar back on it's still OK to run the car. It moves all 4 flaps 1/4 of a turn clockwise on start-up and returns to the left on shutdown. All 3 slave flaps move freely and seems to actuate freely so I can't see why its come off! Did the washer repair on it and have driven it about and is still attached. I have loss of power below 2000RPM which I have read can be the swirl flaps or the EGR valve which I cleaned today but may need replacing. As I can see the flaps moving I don't think its them and I have no black smoke out the back. I also have the spanner light come on at start up but soon goes off. No doubt I'll have to get the manifold changed soon just wanted reassurance it was OK to run it. Thanks!
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    if your swirl flaps are moving freely when you rev it then its fine mate the reason ts fallen o is because of the wear on he ball joints that hold the bar to the flaps or maybe if you have axial movement then it can pop it off too
    if its fixed and working leve it til it falls off again then its a case of biting the bullet
    Bridgend
    Yeah, When I took it out to fit the washers the joints were wonr quite bad but the pegs were fine. I guess as the revs build up it wil move even more? I only saw it move from when the car is off to when it's at idle. I'm guessing as you rev it they will open some more? Will get the wife to rev it tmw whilst I watch them make sure they move fully.
  1. Swirl Bar fallen off
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2012, 19:17
  2. Question from a mate(swirl bar fallen off)
    By justin32 in forum Engine & Drivetrain
    Last Post: 7th October 2011, 22:20
  3. Swirl Rod Linkage
    By bafoo in forum Troubleshooting
    Last Post: 9th July 2010, 16:26
  4. swirl bar fallen off
    By kamar in forum Diesel Engine related
    Last Post: 22nd March 2010, 11:30
  5. Swirl Flap Linkage Rod 'Cheap' Fix
    Last Post: 1st April 2009, 20:58
