Thread: thermostat..warm at last..
    hull
    Default thermostat..warm at last..
    finally got round to changing the thermostat and housing in the vec(1.8sxi 54)
    quoted 45quid for the part off stealers, got one from vaux-world 29quid delivered off ebay. delivered next morning.
    hopefully get better mpg now
    Sunny Dartmoor
    Nice one mate,do you have a link to it,i need to do the same........
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    is it easy.......
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    The thermostat is a piece that gets forgotten too often or should I say its' importance it's neglected too often.
    hull
    Quote Originally Posted by glenboy View Post
    www.vaux-world.com they sell through ebay, just search vec c thermostat.
    part no. 24456401 £29.35 delivered next day.
    took me about half hour,2x torx bolts. no need to drain all coolant off. you will lose a bit when you disconnect the rad pipe but just top up expansion tank when you've finished.
    the stat didn't come with the temp sender but just swap over from the old stat.
    PRESTON
    Wish it was that easy on the 19DT engine, two hours to change, darn thing buried, egr cooler and other stuff in the way, still problem fixed heater toasty again and temp gauge reading right.
    Jun 2007
    in a white box
    christ almighty....they're expensive (for the diesel)
    Sunny Dartmoor
    Quote Originally Posted by frasedeb View Post
    Cheers m8,got our friendly partsman on it...........
  1. whats normal time for thermostat to warm up engine on 120 8v
    By firebeast in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2013, 16:58
  2. only warm air....not hot??
    By bafoo in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 09:12
  3. Car takes a while to warm up, Thermostat? Vec C 1.8 Petrol
    By liam8282 in forum Engine & Drivetrain
    Last Post: 24th September 2011, 13:03
  4. Warm welcome
    By Billythebubble in forum Introduce yourself.
    Last Post: 18th September 2011, 14:58
  5. to warm
    By graham a in forum The 'Off Topic' room
    Last Post: 28th June 2011, 20:33
