Thread: HELP!! Mabye I'm pannicking
    Regular Member mickg's Avatar
    High Wycombe
    Exclamation HELP!! Mabye I'm pannicking
    Hello there. On the way back from work today I just noticed some strange sounds comming from front left wheel. When I'm turning stering wheel I can hear sound like this " klong klong". Just when I'm making a turn. Just don't know what it can be... hopefuly nothing serious and costful ;/
    Ohh... and one more thing when I'm staring engine and it's cold or dumpy weather it makes some squicky sound " twi ti ti twi..." I'm worried about that as well... Any ideas?
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Quote Originally Posted by mickg View Post
    Could be wrong here, but klonk noise could be drop links, and engine noise could be cam belt! Pretty sure someone will 'firm it for ya!
    West
    As above check drop links & also check the springs incase 1 has snapped
    WGAF#5
    agreed - or might just be the spring moving in its seat
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Replace the aux-belt.
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    clonking could be anything! its taken me two years to get mine down to what it is.
    first check the drop links as previously said if there stiff or rusted up get them changed. its a cheap part and you only need two spanners to do it! £15 from eBay if i remeber (just give them a wiggle from side to side and they should move all right and the rubber around the joints should be all nice and not ripped)
    Secondly it might be your front ARB bushes are worn. basicly letting the ARB (Anti Roll Bar) move about these are again a cheap part and there is a handy How2 on here if you need it.
    Thirdly jack the car up and give the springs a good feel up see if you can feel any damage (they are remound for going) mines gone big time before they usually snap at the base of the spring from what i can gather. these are £100 from the stealers but you can get them of eBay dirt cheap. both sides should be done tho if this is the case. also check on the base of the spring has got the rubber/plastic sleave on as this was a vauxhall applied mod on later vecs. if not this is a cheap part im led to belive.
    Fourthly! if its a clonking when turning at slow speeds it might be the suspention top mount has some wear (this is whats up with mine) in which case its nothing to worry about in the short term. its basicly a plastic baring that allows the spring to move when turning and such. its just when the clonking goes to a twanging noise you really need it done as the spring will be coiling itself then releaseing. there about £15 from vaux. if you can disasemble the strut yourself do it and labour will be lots as it means removing the suspention!
    id suggest if the strut has to come out for any reason you might as well get them/you to have a look at the ARB bushes and the drop links as well as they are as ive said very cheap and while its off you might as well get them replaced if they look like there going any time soon!!
    Hope this helps lol ive had no end of sqeeks and rattles and clonks coming from the front end!! Eibachs and bilstens have sorted that tho. just regret not replacing the top mounts while they were off!!!!
    oh yeaah the sqweeky sound will most likly be the aux belt slipping on the engine. easy fix cheap part. you allways hear cars sqeeling down the road with a worn belt on!
    High Wycombe
    ok guys thanks very much for your response. I will check m 'babe" today unles it will be rainning. I will jack it up and check. By the way the noise is on a slow speed.
    thanks one more time. I will let u know whats happened.
    Cambridgeshire
    I was always under the impression that if there is clunking while turning at low speed then you are looking at a new drive shaft?
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    parsco in some carse it is i always thought the sme but its when you put full lock on
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    OK you don't say what engine you have, nor is it in your personal info, so on experience i will guess its a 2.0 / 2.2dti? may be wrong but you are describing the twi - twi of the serpent belt??,(the long flat belt) Get some nylon + rubber lubricant spray from halfords, squirt ONLY! the ribbed side of the belt NOT THE SMOOTH SIDE!!!, As for the clunking does it clunk clunk in time with the wheel speed turning??, or is it a bit more like clunking when generaly turning or going over speed humps??, you can always pm with more info.
  1. I know mabye it will sound silly... but what colour is my car?
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 19:17
